Manager Log List
Log Description
Log path: The default storage path of Manager log files is /var/log/Bigdata/Manager component.
- ControllerService: /var/log/Bigdata/controller/ (operation & maintenance system (OMS) installation and run logs)
 - Httpd: /var/log/Bigdata/httpd (httpd installation and run logs)
 - logman: /var/log/Bigdata/logman (log packaging tool logs)
 - NodeAgent: /var/log/Bigdata/nodeagent (NodeAgent installation and run logs)
 - okerberos: /var/log/Bigdata/okerberos (okerberos installation and run logs)
 - oldapserver: /var/log/Bigdata/oldapserver (oldapserver installation and run logs)
 - MetricAgent: /var/log/Bigdata/metric_agent (MetricAgent run log)
 - omm: /var/log/Bigdata/omm (omm installation and run logs)
 - timestamp: /var/log/Bigdata/timestamp (NodeAgent startup time logs)
 - tomcat: /var/log/Bigdata/tomcat (Web process logs)
 - watchdog: /var/log/Bigdata/watchdog (watchdog logs)
 - Upgrade: /var/log/Bigdata/upgrade (OMS log upgrade)
 - UpdateService: /var/log/Bigdata/update-service (upgrade service log)
 - Sudo: /var/log/Bigdata/sudo (sudo script execution log)
 - OS: /var/log/message file (OS system log)
 - OS Performance: /var/log/osperf (OS performance statistics log)
 - OS Statistics: /var/log/osinfo/statistics (OS parameter configuration log)
Log archive rule:
The automatic compression and archiving function is enabled for Manager logs. By default, when the size of a log file exceeds 10 MB, the log file is automatically compressed. The naming rule of a compressed log file is as follows: <Original log name>-<yyyy-mm-dd_hh-mm-ss>.[ID].log.zip A maximum of 20 latest compressed files are retained.
        Log Type  |
        Log File Name  |
        Description  |
        Controller run log  |
        controller.log  |
        Log file that records component installation, upgrade, configuration, monitoring, alarms, and routine O&M operations  |
        controller_client.log  |
        Run log file of the Representational State Transfer (REST) API  |
        acs.log  |
        Acs run log file  |
        acs_spnego.log  |
        spnego user logs in ACS  |
        aos.log  |
        Aos run log file  |
        plugin.log  |
        Aos plug-in logs  |
        backupplugin.log  |
        Run log file that records the backup and restoration operations  |
        controller_config.log  |
        Configuration run log file  |
        controller_nodesetup.log  |
        Controller loading task log file  |
        controller_root.log  |
        System log file of the Controller process  |
        controller_trace.log  |
        Log file that records the remote procedure call (RPC) communication between Controller and NodeAgent  |
        controller_monitor.log  |
        Monitoring logs  |
        controller_fsm.log  |
        State machine log file  |
        controller_alarm.log  |
        Controller alarm logs  |
        controller_backup.log  |
        Controller backup and recovery logs  |
        install.log, restore_package.log, installPack.log, distributeAdapterFiles.log, install_os_optimization.log  |
        OMS installation log file  |
        oms_ctl.log  |
        OMS startup and stop logs  |
        preInstall_client.log  |
        Preprocessing logs before client installation  |
        installntp.log  |
        NTP installation log file  |
        modify_manager_param.log  |
        Modifying Manager parameter logs  |
        backup.log  |
        OMS backup script running log file  |
        supressionAlarm.log  |
        Alarm script run log file  |
        om.log  |
        OM certificate generation log file  |
        backupplugin_ctl.log  |
        Startup logs of the backup and restoration plug-in process  |
        getLogs.log  |
        Run logs of the collection log script  |
        backupAuditLogs.log  |
        Audit log backup script run log  |
        certStatus.log  |
        Log file that records regular certificate checks  |
        distribute.log  |
        Certificate distribution log  |
        ficertgenetrate.log  |
        Certificate replacement logs, including level-2 certificates, cas certificates, and httpd certificates  |
        genPwFile.log  |
        Log file that records the generation of certificate password files  |
        modifyproxyconf.log  |
        Log file for modifying the HTTPD proxy configuration  |
        importTar.log  |
        Log file that records the process of importing certificates into the trust library.  |
        Httpd  |
        install.log  |
        Httpd installation log file  |
        access_log, error_log  |
        Httpd run log file  |
        logman  |
        logman.log  |
        Log packaging tool log file  |
        NodeAgent  |
        install.log, install_os_optimization.log  |
        NodeAgent installation log file  |
        installntp.log  |
        start_ntp.log  |
        NTP startup log file  |
        ntpChecker.log  |
        NTP check log file  |
        ntpMonitor.log  |
        NTP monitoring log file  |
        heartbeat_trace.log  |
        Log file that records heartbeats between NodeAgent and Controller  |
        alarm.log  |
        Alarm log  |
        monitor.log  |
        Monitoring log file  |
        nodeagent_ctl.log, start-agent.log  |
        NodeAgent startup log file  |
        agent.log  |
        NodeAgent run log file  |
        cert.log  |
        Certificate log file  |
        agentplugin.log  |
        Agent plug-in running status monitoring log file  |
        omaplugin.log  |
        OMA plug-in run log file  |
        diskhealth.log  |
        Disk health check log file  |
        updateHostFile.log  |
        Host list update log file  |
        collectLog.log  |
        Run log of the node log collection script  |
        host_metric_collect.log  |
        Host index collection run log  |
        checkfileconfig.log  |
        Run log file of file permission check  |
        entropycheck.log  |
        Entropy check run log file  |
        timer.log  |
        Log of scheduled node scheduling  |
        pluginmonitor.log  |
        Component monitoring plug-in log  |
        agent_alarm_py.log  |
        Log file that records alarms upon insufficient NodeAgent file permission  |
        okerberos  |
        addRealm.log, modifyKerberosRealm.log  |
        Realm handover log file  |
        checkservice_detail.log  |
        Okerberos health check log file  |
        genKeytab.log  |
        keytab generation log file  |
        KerberosAdmin_genConfigDetail.log  |
        Run log file of generating kadmin.conf when starting the kadmin process  |
        KerberosServer_genConfigDetail.log  |
        Run log file of generating krb5kdc.conf when starting the krb5kdc process  |
        oms-kadmind.log  |
        Run log file of the kadmin process  |
        oms_kerberos_install.log, postinstall_detail.log  |
        Okerberos installation log file  |
        oms-krb5kdc.log  |
        Run log file of the krbkdc process  |
        start_detail.log  |
        Okerberos startup log file  |
        realmDataConfigProcess.log  |
        Log file rollback for realm handover failure.  |
        stop_detail.log  |
        Okerberos stop log file  |
        oldapserver  |
        ldapserver_backup.log  |
        Oldapserver backup log file  |
        ldapserver_chk_service.log  |
        Oldapserver health check log file  |
        ldapserver_install.log  |
        Oldapserver installation log file  |
        ldapserver_start.log  |
        Oldapserver startup log file  |
        ldapserver_status.log  |
        Log file that records the status of the Oldapserver process  |
        ldapserver_stop.log  |
        Oldapserver stop log file  |
        ldapserver_wrap.log  |
        Oldapserver service management log file  |
        ldapserver_uninstall.log  |
        Oldapserver uninstallation log file  |
        restart_service.log  |
        Oldapserver restart log file  |
        ldapserver_unlockUser.log  |
        Log file that records information about unlocking LDAP users and managing accounts  |
        metric_agent  |
        gc.log  |
        MetricAgent JAVA VM gc log file  |
        metric_agent.log  |
        Run log file of MetricAgent.  |
        metric_agent_qps.log  |
        Log file that records MetricAgent Internal queue length and qps information  |
        metric_agent_root.log  |
        All run logs of MetricAgent  |
        start.log  |
        Log file that records information about the MetricAgent startup and stop  |
        omm  |
        omsconfig.log  |
        OMS configuration log file  |
        check_oms_heartbeat.log  |
        OMS heartbeat log file  |
        monitor.log  |
        OMS monitoring log file  |
        ha_monitor.log  |
        HA_Monitor operation log file  |
        ha.log  |
        HA operation log file  |
        fms.log  |
        Alarm log file  |
        fms_ha.log  |
        HA alarm monitoring log file  |
        fms_script.log  |
        Alarm control log file  |
        config.log  |
        Alarm configuration log file  |
        iam.log  |
        IAM log file  |
        iam_script.log  |
        IAM control log file  |
        iam_ha.log  |
        IAM HA monitoring log file  |
        config.log  |
        IAM configuration log file  |
        operatelog.log  |
        IAM operation log file  |
        heartbeatcheck_ha.log  |
        OMS heartbeat HA monitoring log file  |
        install_oms.log  |
        pms_ha.log  |
        pms_script.log  |
        Monitoring control log file  |
        config.log  |
        Monitoring configuration log file  |
        plugin.log  |
        Monitoring plug-in run log file  |
        pms.log  |
        ha.log  |
        HA run log file  |
        cep_ha.log  |
        CEP HA monitoring log file  |
        cep_script.log  |
        CEP control log file  |
        cep.log  |
        CEP log file  |
        config.log  |
        CEP configuration log file  |
        omm_gaussdba.log  |
        GaussDB HA monitoring log file  |
        gaussdb-<SERIAL>.log  |
        GaussDB run log file  |
        gs_ctl-<DATE>.log  |
        GaussDB control log archive log file  |
        gs_ctl-current.log  |
        GaussDB control log file  |
        gs_guc-current.log  |
        GaussDB operation log file  |
        encrypt.log  |
        Omm encryption log file  |
        omm_agent_ctl.log  |
        OMA control log file  |
        oma_monitor.log  |
        OMA monitoring log file  |
        install_oma.log  |
        OMA installation log file  |
        config_oma.log  |
        OMA configuration log file  |
        omm_agent.log  |
        OMA run log file  |
        acs.log  |
        ACS resource log file  |
        aos.log  |
        AOS resource log file  |
        controller.log  |
        Controller resource log file  |
        feed_watchdog.log  |
        feed_watchdog resource log file  |
        floatip.log  |
        Floating IP address resource log file  |
        ha_ntp.log  |
        NTP resource log file  |
        httpd.log  |
        Httpd resource log file  |
        okerberos.log  |
        Okerberos resource log file  |
        oldap.log  |
        OLdap resource log file  |
        tomcat.log  |
        Tomcat resource log file  |
        send_alarm.log  |
        Run log file of the HA alarm sending script of the management node  |
        timestamp  |
        restart_stamp  |
        NodeAgent start time log file  |
        tomcat  |
        cas.log, localhost_access_cas_log.log  |
        CAS run log file  |
        catalina.log, catalina.out, host-manager.log, localhost.log, manager.log  |
        Tomcat run log file  |
        localhost_access_web_log.log  |
        Log file that records the access to REST APIs of FusionInsight Manager  |
        web.log  |
        Run log file of the Web process  |
        northbound_ftp_sftp.log, snmp.log  |
        Northbound logs  |
        perfStats.log  |
        Performance statistics log file  |
        watchdog  |
        watchdog.log, feed_watchdog.log  |
        watchdog run log file  |
        update-service  |
        omm_upd_server.log  |
        UPDServer run log file  |
        omm_upd_agent.log  |
        UPDAgent run log file  |
        update-manager.log  |
        UPDManager run log file  |
        install.log  |
        Installation logs during service upgrade  |
        uninstall.log  |
        Uninstallation logs during service upgrade  |
        catalina.<Time>.log, catalina.out, host-manager.<Time>.log, localhost.<Time>.log, manager.<Time>.log, manager_access_log.<Time>.txt, web_service_access_log.<Time>.txt, catalina.log, gc-update-service.log.0.current, update-manager.controller, update-web-service.controller, update-web-service.log, commit_rm_distributed.log, commit_rm_upload_package.log, common_omagent_operator.log, forbid_monitor.log, initialize_package_atoms.log, initialize_unzip_pack.log, omm-upd.log, register_patch_pack.log, resume_monitor.logrollback_clear_patch.log, unregister_patch_pack.log, update-rcommupd.log, update-rcupdatemanager.log, update-service.log  |
        Run logs during service upgrade  |
        upgrade  |
        upgrade.log_<Time>  |
        OMS upgrade log file  |
        rollback.log_<Time>  |
        OMS rollback log file  |
        sudo  |
        sudo.log  |
        Sudo script execution log file  |
Log Level
Table 2 describes the log levels provided by Manager. The log levels are FATAL, ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the set level are printed by programmer. The number of printed logs decreases as the set log level increases.
        Severity  |
        Description  |
        FATAL  |
        Logs of this level record fatal error information about the current event processing that may result in a system crash.  |
        ERROR  |
        Logs of this level record error information about the current event processing, which indicates that system running is abnormal.  |
        WARN  |
        Logs of this level record abnormal information about the current event processing. These abnormalities will not result in system faults.  |
        INFO  |
        Logs of this level record normal running status information about the system and events.  |
        DEBUG  |
        Logs of this level record system information and system commissioning information.  |
Log Format
The following table lists the Manager log formats.
        Log Type  |
        Component  |
        Format  |
        Example  |
        Controller, Httpd, logman, NodeAgent, okerberos, oldapserver, omm, tomcat, upgrade  |
        <yyyy-MM-dd HH:mm:ss, SSS>|<Log Level>|<Name of the thread for which the log is generated>|<Log message>|<Location where the log event occurs>  |
        2020-06-30 00:37:09,067 INFO [pool-1-thread-1] Completed Discovering Node. com.xxx.hadoop.om.controller.tasks.nodesetup.DiscoverNodeTask.execute(DiscoverNodeTask.java:299)  |
