Configuring Syslog Northbound Parameters
If users need to view alarms and events of a cluster on the unified alarm reporting platform, you can use the Syslog protocol on FusionInsight Manager to report related data to the alarm platform.
   If the Syslog protocol is not encrypted, data may be stolen.
 - Choose System > Interconnection > Syslog.
 - Turn on the switch on the right of Syslog Service.
The Syslog service is disabled by default.
 indicates that the service is enabled. - Set northbound parameters based on information provided in Table 1.
Table 1 Syslog interconnection parameters Parameter Area
Syslog Protocol
Server IP Address Mode
Set the IP address mode of the interconnected server.The value can be IPv4 or IPv6.
Server IP Address
Sets the IP address of the interconnection server.
Server Port
Specifies the port number for interconnection.
Protocol
Sets the protocol type. The available values are as follows:
- TCP
 - UDP
Severity Level
Specifies the severity of the reported message. The options are as follows:
- Emergency
 - Alert
 - Critical
 - Error
 - Warning
 - Notice
 - Informational (default value)
 - Debug
Severity and Facility determine the priority of the sent message.
Priority = Facility × 8 + Severity
For details about the values of Severity and Facility, see Table 2.
Facility
Sets the module where the log is generated. For details about the available value of this parameter, see Table 2. The default value local use 0 (local0) is recommended.
Identifier
Sets the product ID. The default value is FusionInsight Manager.
The identifier can contain a maximum of 256 characters, including letters, digits, underscores (_), spaces, |, $, {, }, periods (.), and hyphens (-).
Report Message
Report Format
Sets the message format of the alarm report. For details, see help information on the page.
The packet can contain letters, digits, underscores (_), spaces, |, $, {, }, periods (.), and hyphens (-), and cannot exceed 1024 characters.
NOTE:For details about the information field in the packet format, see Table 3.
Alarm Type
Sets the type of the alarm to be reported.
Alarm Severities
Sets the level of the alarm to be reported.
Uncleared Alarm Reporting
Periodic Uncleared Alarm Reporting
Sets whether to report uncleared alarms in a specified period. Turn on the switch indicates that the function is enabled, and turn off the switch indicates that the function is disabled. The switch is turned off by default.
Report Interval (min)
Sets the interval at which alarms are reported periodically. This parameter is valid only when the switch is turned on on the right of Periodic Uncleared Alarm Reporting. The default value is 15, in minutes. The value ranges from 5 to 1440 (one day).
Heartbeat Settings
Heartbeat Reporting
Sets whether to periodically report Syslog heartbeat messages. Turn on the switch indicates that the function is enabled, and turn off the switch indicates that the function is disabled. The switch is turned off by default.
Heartbeat Period (min)
Sets the interval at which heartbeat messages are periodically reported. This parameter is valid only when the switch is turned on on the right of Heartbeat Reporting. The default value is 15, in minutes. The value ranges from 1 to 60.
Heartbeat Packet
Sets the heartbeat message to be reported. This parameter is enabled if the switch is turned on on the right of Heartbeat Reporting, and cannot be left blank. The value can contain a maximum of 256 characters, including digits, letters, underscores (_), vertical bars (|), colons (:), spaces, commas (,), and periods (.).
     After the periodic heartbeat packet function is enabled, packets may be interrupted during automatic recovery of some cluster error tolerance (for example, active/standby OMS switchover). In this case, wait for automatic recovery.
 - Click OK to complete the settings.
Related Information
        Severity  |
        Facility  |
        Numeric Code  |
        Emergency  |
        kernel messages  |
        0  |
        Alert  |
        user-level messages  |
        1  |
        Critical  |
        mail system  |
        2  |
        Error  |
        system daemons  |
        3  |
        Warning  |
        security/authorization messages (note 1)  |
        4  |
        Notice  |
        messages generated internally by syslogd  |
        5  |
        Informational  |
        line printer subsystem  |
        6  |
        Debug  |
        network news subsystem  |
        7  |
        UUCP subsystem  |
        8  |
        clock daemon (note 2)  |
        9  |
        security/authorization messages  |
        10  |
        FTP daemon  |
        11  |
        NTP subsystem  |
        12  |
        log audit (note 1)  |
        13  |
        log alert (note 1)  |
        14  |
        clock daemon  |
        15  |
        local use 0~7 (local0 ~ local7)  |
        16 to 23  |
        Information Field  |
        Description  |
        dn  |
        Cluster name  |
        id  |
        Alarm ID  |
        name  |
        Alarm name  |
        serialNo  |
        Alarm serial number
         The sequence numbers of the fault alarms and the corresponding recovery alarms are the same.  |
        category  |
        Alarm type. The options are as follows:
        occurTime  |
        Time when the alarm was generated  |
        clearTime  |
        Time when this alarm is cleared  |
        isAutoClear  |
        Whether an alarm is automatically cleared. The options are as follows:
        locationInfo  |
        Location where the alarm is generated  |
        clearType  |
        Alarm clearance type. The options are as follows:
        level  |
        Severity. The options are as follows:
        cause  |
        Alarm cause  |
        additionalInfo  |
        Additional information  |
        object  |
        Alarm object  |
