Updated on 2022-08-12 GMT+08:00
Clearing Queue Configurations
The system administrator can clear queue configurations on FusionInsight Manager if a queue does not need resources from a resource pool or a resource pool needs to be disassociated from a queue. Clearing queue configurations means that the resource capacity policy of a queue in the resource pool is canceled.
If a queue is to be unbound from a resource pool, you have ensured that the resource pool is not the default resource pool of the queue. For details, see Configuring a Queue.
  1. Log in to FusionInsight Manager portal.
  2. Choose Tenant Resources > Dynamic Resource Plan
  3. Set Cluster to the name of the cluster to be operated. In Resource Pool, select the specified resource pool.
  4. Locate the row that contains the specified queue in Resource Allocation and click Clear in the Operation column.
  5. In Clear Queue Configuration, click OK to clear the queue configurations in the current resource pool.
