Managing the Client
FusionInsight Manager supports unified management of client installation information in a cluster. After a user downloads and installs the client, FusionInsight Manager automatically records information about the installed (registered) client to facilitate query and management. In addition, you can manually add or modify the information about clients that are not automatically registered, for example, clients installed in earlier versions.
Viewing client information
- Choose Cluster > Name of the desired cluster > Client Management to view the information about the installed clients in the cluster. You can view the IP address, installation path, component list, registration time, and installation user of the node where the client is located. When you download and install the client of the latest version, the client information is automatically registered.
Adding client information
- If you need to manually add information for an installed client, click Add and manually add the IP address, installation path, user, platform information, and registration information of the client as prompted.
- Configure the client information and click OK.
Modifying client information
- Information of a manually registered client can be manually modified.
On the Client Management page, select the desired client and click Modify. After information is modified, click OK.
Deleting client information
- On the Client Management page, select the desired client and click Delete. In the displayed dialog box, click OK.
To delete information of multiple clients, select the desired clients and click Batch Delete. In the displayed dialog box, click OK.
Exporting client information
- On the Client Management page, click Export All to export information about all registered clients to the local PC.
   On the Client Management page, only components that have clients are displayed in the component list. Therefore, some components that do not have clients and special components are not displayed.
The following components are not displayed:
LdapServer, KrbServer, DBService, Hue, Mapreduce, and Flume
