Editing Properties
The Property tab displays information about the properties of the selected vertices and edges. You can edit the properties of a single vertex or edge.
- Right-click a vertex/edge in the canvas and choose View Property from the shortcut menu. The Property tab is displayed on the right, showing the properties of the selected vertex/edge.
- Click next to the property to edit it.
Click Edit All at the bottom of the property area to edit all the displayed properties. Click Save All.
- Click after you finish editing.
In the Property tab, only the properties of a single vertex or edge can be edited. In the Schema tab of the metadata area, you can add or delete all properties of a tag, as described in section Editing Schema.
