Updated on 2025-07-07 GMT+08:00
Key CCE AI Suite (NVIDIA GPU) Parameters
Check Items
Check whether the configuration of CCE AI Suite (NVIDIA GPU) in a cluster has been intrusively modified. If so, upgrading the cluster may fail.
Solution
  1. Use kubectl to access the cluster.
  2. Run the following command to obtain the add-on instance details:
    kubectl get ds nvidia-driver-installer -nkube-system -oyaml
  3. Check whether the UpdateStrategy value is changed to OnDelete. If so, change it back to RollingUpdate.
  4. Check whether the NVIDIA_DRIVER_DOWNLOAD_URL value is the same as the GPU driver version on the add-on page. If not, correct the version on the add-on page.
