Residual Nodes
Check Items
Check whether nodes need to be migrated.
Solution
This issue is caused by either an error in the node's package pull component or the absence of key system components on the node, which could be due to an upgrade from an earlier version.
Solution 1
Log in to the CCE console and click the cluster name to access the cluster console. Choose Nodes in the navigation pane. Locate the row containing the target node and choose More > Reset Node in the Operation column. For details, see Resetting a Node. After the node is reset, retry the check task.
Resetting a node will reset all node labels, which may affect workload scheduling. Before resetting a node, check and retain the labels that you have manually added to the node.
Solution 2
After creating a node, delete the faulty node.
