- What's New
- Function Overview
- Product Bulletin
Billing
- Billing Overview
- Billing Modes
- Billed Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- How Is CBR Billed?
- What Is the Billing Cycle of Pay-per-Use Vaults?
- How Do I Disable CBR?
- How Do I Unsubscribe from CSBS or VBS Resource Packages?
- Why Is a Message Displayed Indicating Insufficient User Rights When I Create a Policy?
- What Can I do If a Yearly/Monthly-Billed Vault Is About to Expire?
- How Do I Unsubscribe from a Vault?
- What Should I Do If the Fee Is Too High When I Expand the Capacity of a Vault?
- Why Are CBR Backups Displayed on the VBS Console?
- How Do I Purchase a CBR Replication Traffic Package?
- What Resources Do I Need to Implement Cross-Region Backup Replication?
- Why AM I Still Being Billed After a Resource is Deleted?
- Getting Started
User Guide
- Management permissions
Vault Management
- Overview
- Viewing a Vault
- Deleting a Vault
- Associating Resources to a Vault
- Dissociating Resources from a Vault
- Migrating Resources from a Vault
- Expanding Vault Capacity
- Reducing Vault Capacity
- Changing from Pay-per-Use to Yearly/Monthly
- Changing Vault Specifications
- Replicating a Vault Across Regions
- Managing Vault Tags
- Managing the Enterprise Projects of Vaults
- Enabling Backup Locking
- Backup Management
- Policy Management
- Organizational Policy Management
- Application-Consistent Backup
- File Backup (Supported Conditionally)
Restoring Data
- Restoring from a Cloud Server Backup
- Creating an Image from a Cloud Server Backup
- Restoring from a Cloud Disk Backup
- Creating a Disk from a Cloud Disk Backup
- Creating a File System from an SFS Turbo Backup
- Restoring from a Desktop Backup
- Restoring from a File Backup
- Restoring from a Hybrid Cloud Backup
- (Optional) Migrating Resources from CSBS/VBS
- Managing Tasks
- Cloud Eye Monitoring
- Recording CBR Operations Using CTS
- Quotas
- Appendix
Hybrid Cloud Backup Feature Guide
- Hybrid Cloud Backup
- Application Scenarios
- Constraints and Limitations
VMware Backup
- VMware Backup Process
- Downloading and Installing eBackup
- Configuring eBackup
- Adding a VMware Protected Environment
- Preparing for VMware Backup Storage
- Performing VMware Backup
- Restoring Data Using VMware Backups
- Managing a Protected VMware Environment
- Managing VMware Backup Storage
- Managing VMware Backups
- Common Operations
Best Practices
Using a Custom Script to Implement Application-Consistent Backup
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Verifying the Application-Consistent Backup Result
- Protecting SQL Server
- Troubleshooting a Custom Script Error
- Performing Periodic Recovery Drills Using the Backup Data
- Creating Backup Policies Based on Service Tiering
API Reference
- Before You Start
- API Overview
- Calling APIs
CBR APIs
- Tasks
- Protection
- Backups
- Backup Sharing
Vaults
- Creating a Vault
- Querying a Specified Vault
- Querying the Vault List
- Modifying a Vault
- Deleting a Vault
- Applying a Policy to a Vault
- Removing a Policy from a Vault
- Querying the Vault List in Other Regions
- Batch Modifying Vaults
- Setting Auto Backup for a Vault
- Creating a Yearly/Monthly Vault
- Querying Vault Usage of a Project
- File Backup
- Tags
- Policies
- Organizational Policies
- Metering
- Operations
- Restore Points
- Projects
- Application Cases
- Appendix
- SDK Reference
Troubleshooting
- Failed to Execute a Backup Task
- Failed to Delete a Backup
- Failed to Expand the Vault Capacity
- Failed to Attach Disks
- Data Disks Are Not Displayed After a Windows Server Is Restored
- Failed to Cancel Backup Sharing
- Failed to Download or Install the Agent Required by Application-Consistent
- Failed to Install the Agent on Windows
- Failed to Implement Application-Consistent Backup
- A Server Created Using an Image Enters Maintenance Mode After Login
- Failed to Migrate VMware Backups to the Cloud
- Failed to Restore a VMware Backup to a Cloud Server
- An Error Message Is Displayed Indicating that the Path of a Storage Unit Is Invalid
- Failed to Import an eBackup Image Template, with an Error Displayed Indicating That the File Is Invalid
- The Download Dialog Box Disappears When I Download eBackup on a VMware VM
- File Backup Failed Due to Inconsistent Time Between Backup Client and UTC Time
- Concepts
Billing
- Can I Change a Server Backup Vault to a Disk Backup Vault or the Other Way Around?
- What Charges Will I Incur When Using a Backup to Create an Image?
Backup
- Do I Need to Stop the Server Before Performing a Backup?
- Can I Back Up a Server Deployed with Databases?
- How Can I Distinguish Automatic Backups From Manual Backups?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CBR Support Cross-Region Backup?
- How Do I Migrate Server Data Across Regions Using Server Backups?
- Can I Back Up Two Disks to One Target Disk?
- How Do I Replicate a Disk to the Same AZ in a Region as the Source Disk?
- Can I Migrate Backups Between Vaults?
- Can I Use Its Backup for Restoration After a Resource Is Deleted?
- How Many Backups Can I Create for a Resource?
- Can I Use an Incremental Backup to Restore Data After a Full Backup Is Deleted?
- Can I Stop an Ongoing Backup Task?
- How Do I Reduce the Vault Space Occupied by Backups?
- How Do I View the Size of Each Backup?
- How Do I View My Backup Data?
- How Long Will My Backups Be Kept?
- How Do I Implement Periodic Full Backups for My Resources?
- How Do I Query Resources that Have not Been Backed Up?
- Is There Any Requirement on the Network Bandwidth During Data Backup?
Capacity
- How Large of a Vault Do I Need?
- Why Is My Backup Size Larger Than My Disk Size?
- What Can I Do If the Vault Capacity Is Not Enough?
- Why Does the Used Capacity of a Vault Change Only Slightly After I Deleted Unwanted Backups?
- Will Backup Continue If the Usage of a Vault Reaches the Upper Limit?
- How Do I Adjust the Vault Capacity Alarm Threshold?
Restoration
- Do I Need to Stop the Server Before Restoring Data Using Backups?
- Can I Use a System Disk Backup to Recover an ECS?
- Do I Need to Stop the Server Before Restoring Data Using Disk Backups?
- Can a Server Be Restored Using Its Backups After It Is Changed?
- Can a Disk Be Restored Using Its Backups After Its Capacity Is Expanded?
- What Can I Do if the Password Becomes a Random One After I Use a Backup to Restore a Server or Use an Image to Create a Server?
- What Changes Will Be Made to the Original Backup When I Use the Backup to Restore a Server?
- How Do I Restore Data to a New Server?
- How Do I Restore a Data Disk Backup to a System Disk?
- Can I Use CBR to Restore Data to Any Point When the Data Was Backed Up?
- Can I Stop an Ongoing Restoration Task?
Policies
- How Do I Configure Automatic Backup for a Server or Disk?
- Why the New Retention Rule I Changed Is Not Applied?
- How Do I Back Up Multiple Resources at a Time?
- How Do I Retain My Backups Permanently?
- How Can I Cancel Auto Backup or Auto Replication?
- How Can I Have the System Automatically Delete Backups That I No Longer Need?
- Why Aren't My Backups Deleted Based on the Retention Rule?
- Optimization
- Is There a Quota for CBR Vaults?
- Can I Merge My Vaults?
- How Do I Delete a Backup That Has Been Used to Create an Image While Retaining the Image?
- Can I Export Disk Backup Data to Another Server?
- Why Do I Need a Vault to Accept the Image Shared to Me?
- Can I Download Backup Data to a Local PC?
- How Do I Copy Disk Data to Another Account?
- Videos
More Documents
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
- Billing
Backup
- Will the Server Performance Be Affected If I Delete Its Backups?
- Capacity
Restoration
Policies
- How Can I Cancel Auto Backup?
- Optimization
- Troubleshooting Cases
- Appendix
- API Reference (ME-Abu Dhabi Region)
Best Practices (ME-Abu Dhabi Region)
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
User Guide (Paris)
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Auditing
- Quotas
- Concepts
Backup
- Capacity
Restoration
Policies
- Optimization
- Appendix
- API Reference (Paris)
Best Practices (Paris)
- Change History
- Getting Started
- Permissions Management
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
Backup
Restoration
- Policies
- Others
- Appendix
- API Reference (Kuala Lumpur Region)
Best Practices (Kuala Lumpur Region)
- Change History
User Guide (Ankara Region)
- Getting Started
- Vault Management
- Backup Management
- Policy Management
- Restoring Data
- Managing Tasks
- Monitoring
- Quotas
- Concepts
Backup
- Capacity
Restoration
- Policies
- Others
- Appendix
- API Reference (Ankara Region)
Best Practices (Ankara Region)
- Change History
- Glossary
Installing the Agent
Before enabling application-consistent backup, change the security group and successfully install the Agent on your ECSs.
If application-consistent backup is enabled but Agent is not installed on servers, application-consistent backup will fail, and a common server backup will be performed instead. To ensure that application-consistent backup is properly executed, download and install the Agent first.
Operation Instructions
- During the Agent installation, the system requires the rdadmin user's permissions to run the installation program. To improve O&M security, change the user rdadmin's password of the Agent OS regularly and disable this user's remote login permission. For details, see Changing the Password of User rdadmin.
- Table 1 lists OSs that support installation of the Agent.
Table 1 OSs that support installation of the Agent Database
OS
Version
SQL Server 2008/2012
Windows
Windows Server 2008, 2008 R2, 2012, and 2012 R2 for x86_64
SQL Server 2014/2016/EE
Windows
Windows Server 2014, 2014 R2, and 2016 Datacenter for x86_64
MySQL 5.5/5.6/5.7
Red Hat
Red Hat Enterprise Linux 6 and 7 for x86_64
SUSE
SUSE Linux Enterprise Server 11 and 12 for x86_64
CentOS
CentOS 6 and 7 for x86_64
EulerOS
EulerOS 2.2 and 2.3 for x86_64
HANA 1.0/2.0
SUSE
SUSE Linux Enterprise Server 12 for x86_64
To install the Agent, the system will open the firewall of a port from 59526 to 59528 of the ECS. When port 59526 is occupied, the firewall of port 59527 is enabled, and so on.
- You have obtained a username and its password for logging in to the management console.
- The security group has been configured.
- The Agent Status of the ECS is Not installed.
- If you use Internet Explorer, you need to add the websites you will use to trusted sites.
Installing the Agent for a Linux OS (Method 1)
- Click the Agent Installation tab.
- In method 1, select the corresponding Agent version as required, and copy the installation command in step 2.
- On the ECS page, select the target server and click Remote Login in the Operation column to log in to the ECS.
- Paste the installation command in step 2 to the server and run the command as user root. If the execution fails, run the yum install -y bind-utils command to install the dig module. If the installation still fails, use method 2 to install the Agent for a Linux OS.
- After the installation is complete, Agent is running properly. To implement application-consistent backup for MySQL, SAP HANA, or other types of databases, modify or compile a custom script by referring to the Cloud Backup and Recovery Best Practices.
Installing the Agent for a Linux OS (Method 2)
- In method 2, click Download. On the displayed download client dialog box, select the version to be downloaded based on the operating system type of the target ECS, and click OK.
- After downloading the Agent, use a file transfer tool, such as Xftp, SecureFX, or WinSCP, to upload the Agent installation package to your ECS.
- After the upload, go to the ECS page. Select the target server and click Remote Login in the Operation column to log in to the ECS.
- Run the tar -zxvf command to decompress the Agent installation package to any directory and run the following command to go to the bin directory:
cd bin
- Run the following command to run the installation script:
sh agent_install_ebk.sh
- The system displays a message indicating that the client is installed successfully. See Figure 1.
- If the MySQL or SAP HANA database has been installed on the ECS, run the following command to encrypt the password for logging in to the MySQL or SAP HANA database:
/home/rdadmin/Agent/bin/agentcli encpwd
- Use the encrypted password in 8 to replace the database login password in the script in /home/rdadmin/Agent/bin/thirdparty/ebk_user/.
Installing the Agent for a Windows OS (Method 1)
- In method 1, click Download. Save the downloaded installation package to a local directory.
- Log in to the console and then log in to the ECS as the administrator.
- Decompress the installation package to any directory and go to the Installation path\bin directory.
- Double-click the agent_install_ebk.bat script to start the installation.
- The system displays a message indicating that the client is installed successfully. See Figure 2.
Installing the Agent for a Windows OS (Method 2)
- On the ECS page, select the target server and click Remote Login in the Operation column to log in to the ECS as the administrator.
- Copy the installation commands in step 2 of method 2 to the server and run the command in the Command Prompt.
- Copy any IP address in the response name, paste it in the address box of the browser, and replace 0.0.0.0 in the following address with the address. Replace region1 with the actual region. The following command uses region1 as an example. Then, press Enter in the browser to download the installation package.
http://0.0.0.0/csbs-agent-region1/Cloud Server Backup Agent-WIN64.zip
- Decompress the file to obtain the installation file. Decompress the installation package to any directory and go to the Installation path\bin directory.
- The system displays a message indicating that the client is installed successfully. See Figure 3.
