Help Center/ Managed Threat Detection/ FAQs/ About the Product/ How Do I Get Started with MTD After Purchasing It?
Updated on 2023-06-13 GMT+08:00
Before you use MTD, you need to create a detector and configure a tracker.
Step 1: Create a Detector
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the left navigation pane and choose Security & Compliance > Managed Threat Detection.
    Figure 1 Home page of the MTD console
  4. Click Create Now in the Create Detector pane. After the creation is complete, Detector created. is displayed. The page is automatically refreshed. Click in the upper left corner of the page to show the Process Flow. If Create Detector is checked as shown in Detector created successfully, the detector is created.
    Figure 2 Detector created successfully
Step 2: Create a Tracker
CTS threat detection is not supported for CN-Hong Kong. The tracker does not work in CN-Hong Kong.
  1. View the notice on the Detection Result page. The notice asks you to create a tracker.
    Figure 3 Notice on the detection result page
  2. Click Creating a Tracker to switch to the CTS Tracker List page. In the tracker list, locate the only default tracker which is of the Management type.
    You do not need to create the Management tracker as it is created by the system.
    Figure 4 Management tracker
  3. Click Configure in the Operation column of the target tracker. In the displayed Configure Tracker dialog box, enable Trace Analysis and set other parameters as required.
    Figure 5 Enabling event analysis
  4. Click in the left navigation pane and choose Security & Compliance > Managed Threat Detection.
  5. In the left navigation pane, choose Settings > Detection Settings. On the Detection Settings page, click next to Cloud Trace Service (CTS). In the displayed dialog box, click OK to temporarily disable CTS threat detection. Operation successfully! is displayed in the upper right corner.
    Figure 6 Disabling CTS
  6. Click behind Cloud Trace Service Log (CTS) to enable CTS threat detection. Operation successfully! is displayed in the upper right corner.
    Figure 7 Enabling CTS detection
  7. In the navigation pane on the left, choose Detection Result. On the displayed page, check that the notice asking you to create a tracker disappears, and that CTS log is enabled. The tracker is configured successfully.
    Figure 8 Tracker configured
