EVS Recycle Bin
If EVS recycle bin is enabled, EVS disks will be moved to the recycle bin upon deletion. This can help protect your disk data from accidental deletions.
EVS recycle bin is disabled by default. You need to manually enable it before you can use it.
You first have to configure a recycle bin policy to define when to move deleted disks to the bin. Then, disks will be moved there based on the configured policy.
Related Operations
