EVS Billing
You will be billed for the storage capacity based on the disk type and for how long you use a disk. There are yearly/monthly and pay-per-use billing modes, and you can change the billing mode if needed.
Item |
Yearly/Monthly |
Pay-per-Use |
Billed usage period |
Prepaid |
Postpaid The disk usage is calculated by the second but billed every hour. If your usage is less than an hour, you are billed based on the actual duration consumed. |
Billing for capacity expansion |
Disk capacity can be expanded. You need to pay for the price difference. |
Postpaid You will be billed for the new capacity after the expansion is complete. |
Billing for performance change |
The disk performance (throughput and IOPS) does not support yearly/monthly billing. For yearly/monthly EVS disks that allow you to configure the disk performance, yearly/monthly billing only applies to the disk capacity, and the disk performance is billed on a pay-per-use basis. This is also true after a performance change. |
The disk performance can only be billed on a pay-per-use basis. The performance is billed on a pay-per-use basis after a performance change. |
Billing for disk type change |
The disk is billed on a pay-per-use basis after a disk type change. |
Billed Usage Period
Billing starts
You will be billed for the EVS disks right after you have purchased them.
Billing ends
- For a yearly/monthly disk, the billing ends after the disk is successfully unsubscribed from, and you will be refunded based a certain ratio. For details, see Unsubscriptions.
- For a pay-per-use disk, the billing ends after the disk is successfully deleted.
For more information, see Billing.
