- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Pipeline Usage
- Enabling and Authorizing CodeArts Pipeline
- Accessing CodeArts Pipeline
- Creating a Pipeline
- Configuring a Pipeline
- Grouping Pipelines
- Executing a Pipeline
- Checking a Pipeline
- Configuring a Change-triggered Pipeline
- Managing Pipeline Extensions
- Creating Service Endpoints
- Checking Audit Logs
- Reference
- CodeArts Release User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Template Management
Pipeline Management
- Starting a Pipeline
- Obtaining Pipeline Statuses in Batches
- Obtaining Pipeline Status/Obtaining Pipeline Execution Details
- Obtaining Pipeline List/Pipeline Execution Status in a Project
- Deleting a Pipeline
- Querying Pipeline Details
- Editing a Pipeline
- Stopping a Pipeline
- Obtaining Pipeline Execution Records
- Creating a Pipeline With a Template
- Retrying a Pipeline
- Passing Manual Review
- Rejecting Manual Review
- Querying Pipeline Logs
- Obtaining the Pipeline Step Execution Output
- Querying Build Products on a Pipeline
- Group Management
- Rule Management
- Tenant-level Policy Management
- Project-level Policy Management
Extension Management
- Creating an Extension Version
- Creating an Extension Draft Version
- Creating a Publisher
- Updating an Extension Draft
- Publishing an Extension Draft
- Updating Basic Information of an Extension
- Binding an Extension to a Publisher
- Updating the Extension Icon
- Updating the Publisher Icon
- Deleting an Extension Draft
- Querying the Publisher List
- Querying the Available Publisher
- Querying the Available Extension List
- Querying the Basic Extension List
- Querying the Available Extensions by Page
- Querying the Extension List
- Querying Extension Indicator Configuration
- Query Extension Input Configuration
- Query Extension Output Configuration
- Querying All Versions of an Extension
- Querying Extension Version Details
- Querying the Extension Version
- Deleting a Publisher
- Querying Publisher Details
- Creating a Basic Extension
- Updating a Basic Extension
- Deleting a Basic Extension
- Uploading a Basic Extension
- Querying the Basic Extension Details
- Template Management (Old Version, Unavailable Soon)
Pipeline Management (Old Version, Unavailable Soon)
- Quickly Creating a Pipeline and Jobs with a Template
- Checking the Pipeline Creation Status
- Obtaining the Pipeline List
- Obtaining the Pipeline Status
- Obtaining the Pipeline Execution Status in a Project
- Application Examples
- Appendixes
- Change History
- Functions
Troubleshooting
- Pipeline Fails to Run Because Repository Not Found
- Pipeline Fails to Run Because the Test Suite Is Already in Progress
- Pipeline Fails to Run Because Job Not Found
- Pipeline Is Not Triggered at a Specified Time
- Execution Button Is Unavailable
- Inappropriate Reviewer Configured for the Manual Review Job
- Subpipeline Not Found
- Change-triggered Pipeline Fails to Run and an Error Message Is Returned: "authentication required"
- Pipeline Fails to Run Because Deployment Policy Not Found
- Videos
Show all
Function Overview
OBS 2.0 Supported
CodeArts Pipeline provides visualized continuous integration and continuous delivery (CI/CD) pipelines that can be orchestrated. It helps enterprises quickly realize continuous delivery and efficient automation in DevOps, shortens the time to market (TTM) of applications, and improves R&D efficiency.
CodeArts Pipeline is essentially a visualized and automated task scheduling platform. It needs to be used together with automated tasks of services such as CodeArts Build, CodeArts Check, CodeArts TestPlan, and CodeArts Deploy in CodeArts. You can orchestrate these automation tasks based on your requirements, such as application deployment in the development, test, or production environment. After the tasks are configured, they can be automatically triggered, scheduled, and executed, avoiding frequent and inefficient manual operations.
All regions.
OBS 2.0 Supported
A pipeline can manage and orchestrate automatic tasks of other services. You can orchestrate pipeline stages and tasks based on production and delivery workflows when creating, copying, and editing pipelines.
All regions.
OBS 2.0 Supported
An associated pipeline can be automatically executed when the following conditions are met.
- Continuous integration
- Code is committed in an associated code repository. The related branch and path of changed files meet inclusion and exclusion policies.
- A tag is created in an associated code repository. The created tag meets inclusion and exclusion policies.
- Merge request (MR)
An MR event is triggered to create, update, merge, or re-open code in an associated code repository. The related branch is in the configured scope. The branch and path of changed files meet inclusion and exclusion policies.
- Scheduled execution
The execution date and time is configured and reached.
All regions.
OBS 2.0 Supported
Pipeline parameters can be transferred (referenced by ${parameter name}) for unified data flows among tasks. You only need to configure pipeline parameters to streamline data for tasks such as build, deployment, and API test. Pipeline parameters are classified into the following types:
- Custom parameters: You can customize character string, enumeration, auto-increment, and host group types.
- System parameters: Default parameters do not need to be defined and cannot be deleted or modified. These parameters include PROJECT_ID, PIPELINE_ID, PIPELINE_NUMBER, COMMIT_ID and TIMESTAMP.
All regions.
OBS 2.0 Supported
Pipeline permissions can be configured by role and personnel.
- The permissions of project creators and pipeline creators cannot be changed.
- Personnel permissions are prioritized over role permissions.
- The view permission is enabled by default and cannot be disabled.
- If the run permission is disabled, edit and delete permissions are disabled at the same time.
- If the edit permission is enabled, the run permission is enabled at the same time.
- If the edit permission is disabled, the delete permission is disabled at the same time.
- If the delete permission is enabled, edit and run permissions are enabled at the same time.
All regions.
OBS 2.0 Supported
You can configure message notifications to send service updates or emails to related personnel when a pipeline is deleted, fails to be executed, is successfully executed, or the configuration is updated. Managing the Recycle Bin.
All regions.
