On this page
Backing Up IoTDB Metadata
Updated on 2024-10-11 GMT+08:00
To ensure IoTDB metadata security and prevent the IoTDB service from being unavailable due to IoTDB metadata file damages, you need to back up IoTDB metadata. The backup data can be used to recover the system if an exception occurs or the operation has not achieved the expected result, minimizing the adverse impacts on services.
You can create a backup task on FusionInsight Manager to back up IoTDB metadata. Both automatic and manual backup tasks are supported.
  • The backup type, period, policy, and other specifications have been planned based on the service requirements and you have checked whether Data storage path/LocalBackup/ has sufficient space on the active and standby management nodes.
  • If you want to back up data to NAS, you have deployed the NAS server in advance.
  • Time is consistent between the active and standby clusters and the NTP services on the active and standby clusters use the same time source.
  • Backup policies, including the backup task type, period, backup object, backup directory, and Yarn queue required by the backup task are planned based on service requirements.
  • The HDFS in the standby cluster has sufficient space. You are advised to save backup files in a custom directory.
  1. On FusionInsight Manager, choose O&M > Backup and Restoration > Backup Management.
  2. Click Create.
  3. Set Name to the name of the backup task.
  4. Select the cluster to be operated from Backup Object.
  5. Set Mode to the type of the backup task.
    Periodic indicates that the backup task is executed by the system periodically. Manual indicates that the backup task is executed manually.
    Table 1 Periodic backup parameters
    Started
    Indicates the time when the task is started for the first time.
    Period
    The task execution interval. Value options include Hours and Days.
    Backup Policy
    Indicates a periodic backup policy.
    • Full backup at the first time and incremental backup subsequently
    • Full backup every time
    • Full backup once every n times
    Incremental backup is not supported when component metadata is backed up. Only Full backup every time is supported.
  6. In Configuration, select IoTDB under Metadata and other data.
    If there are multiple IoTDB services, all IoTDB services are backed up by default. You can click Assign Service to specify the services to be backed up.
  7. Set Path Type of IoTDB to a backup directory type.
    The following backup directory types are supported:
    • LocalDir: indicates that the backup files are stored on the local disk of the active management node and the standby management node automatically synchronizes the backup files. By default, the backup files are stored in Data storage path/LocalBackup/.
      If you select this option, you need to set the maximum number of replicas to specify the number of backup file sets that can be retained in the backup directory.
    • NFS: indicates that backup files are stored in the NAS using the NFS protocol.
      If you select this option, set the following parameters:
      • IP Mode: indicates the mode of the target IP address. The system automatically selects the IP address mode based on the cluster network type, for example, IPv4 or IPv6.
      • Server IP Address: indicates the IP address of the NAS server.
      • Server Shared Path: indicates the configured shared directory of the NAS server. (The shared path of the server cannot be set to the root directory, and the user group and owner group of the shared path must be nobody:nobody.)
      • Maximum Number of Backup Copies: indicates the number of backup file sets that can be retained in the backup directory.
    • RemoteHDFS: indicates that the backup files are stored in the HDFS directory of the standby cluster.
      • Destination NameService Name: indicates the NameService name of the standby cluster, for example, hacluster. You can obtain it from the NameService Management page of HDFS of the standby cluster.
      • Destination Active NameNode IP Address: indicates the service plane IP address of the active NameNode in the standby cluster.
      • Destination Standby NameNode IP Address: indicates the service plane IP address of the standby NameNode in the standby cluster.
      • Destination NameNode RPC Port: indicates the value of dfs.namenode.rpc.port in the HDFS basic configuration of the standby cluster.
      • Target Path: indicates the HDFS directory for storing standby cluster backup data. The storage path cannot be an HDFS hidden directory, such as a snapshot or recycle bin directory, or a default system directory, such as /hbase or /user/hbase/backup.
    • CIFS: indicates that backup files are stored in the NAS using the CIFS protocol.
      • Port: indicates the port number used to connect to the NAS server over the CIFS protocol. The default value is 445.
      • Username: indicates the username set when the CIFS protocol is configured.
      • Password: indicates the password set when the CIFS protocol is configured.
    • SFTP: indicates that backup files are stored in the server using the SFTP protocol.
      • Server IP Address: indicates the IP address of the server where the backup data is stored.
      • Port: indicates the port number used to connect to the backup server over the SFTP protocol. The default value is 22.
      • Username: indicates the username for connecting to the server using the SFTP protocol.
      • Password: indicates the password for connecting to the server using the SFTP protocol.
      • Server Shared Path: indicates the backup path on the SFTP server.
  8. Click OK.
  9. In the Operation column of the created task in the backup task list, click More and select Back Up Now to execute the backup task.
    After the backup task is executed, the system automatically creates a subdirectory for each backup task in the backup directory. The format of the subdirectory name is Backup task name_Task creation time, and the subdirectory is used to save data source backup files.
    The format of the backup file name is Version_Data source_Task execution time.tar.gz.
