On this page
Configuring the Number of Local Audit Log Backups
Updated on 2024-10-11 GMT+08:00
Audit logs of cluster components are classified by name and stored in the /var/log/Bigdata/audit directory on each cluster node. The OMS automatically backs up the audit log directories at 03:00 every day.
The audit log directory on each node is compressed and named in the <Node IP address>.tar.gz format. All compressed files are compressed and named in the <yyyy-MM-dd_HH-mm-ss>.tar.gz format and saved in the /var/log/Bigdata/audit/bk/ directory on the active management node. In addition, the standby management node saves a copy of the file.
By default, a maximum of 90 OMS backup files can be retained. This section describes how to configure the maximum number.
  1. Log in to the active management node as user omm.
    Perform this operation only on the active management node. This operation is not supported on the standby management nodes; otherwise, the cluster cannot work properly.
  2. Run the following command to switch to the required directory:
    cd ${BIGDATA_HOME}/om-server/om/sbin
  3. Run the following command to change the maximum number of audit log backup files to be retained:
    ./modifyLogConfig.sh -m Maximum number of backup files that can be retained
    The default value is 90. The value ranges from 0 to 365. A larger value means to consume more disk space.
    If the following information is displayed, the operation is successful:
    Modify log config successfully
