On this page
Updating the Configuration of an Installed Client
Updated on 2024-10-11 GMT+08:00
The cluster provides a client for you to connect to a server, view task results, or manage data. If you modify service configuration parameters on FusionInsight Manager and restart the service, you need to download and install the installed client again or use the configuration file to update the client.
You have installed a client.
Method 1:
  1. Log in to FusionInsight Manager. Click the wanted cluster from the Cluster drop-down list.
  2. Click More and select Download Client. In the Download Cluster Client dialog box, select Configuration Files Only.
    The generated compressed file contains the configuration files of all services.
  3. Determine whether to generate a configuration file on the cluster node.
    • If yes, select Save to Path, and click OK to generate the client file. By default, the client file is generated in /tmp/FusionInsight-Client on the active management node. You can also store the client file in other directories, and user omm has the read, write, and execute permissions on the directories. Then, go to 4.
    • If no, click OK and specify a local save path to download the complete client. Wait until the download is complete, and go to 4.
  4. Use WinSCP to save the compressed file to the installation directory of the client as the client installation user, such as /opt/hadoopclient.
  5. Decompress the software package.
    Run the following commands to go to the directory where the client is installed, and decompress the file to a local directory. For example, the downloaded client file is FusionInsight_Cluster_1_Services_Client.tar.
    cd /opt/hadoopclient
    tar -xvf FusionInsight_Cluster_1_Services_Client.tar
  6. Verify the software package.
    Run the following command to verify the decompressed file and check whether the command output is consistent with the information in the sha256 file:
    sha256sum -c FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles.tar.sha256
    FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles.tar: OK
  7. Decompress the package to obtain the configuration file.
    tar -xvf FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles.tar
  8. Run the following command in the client installation directory to update the client using the configuration file:
    sh refreshConfig.sh Client installation directory Directory where the configuration file is located
    For example, run the following command:
    sh refreshConfig.sh /opt/hadoopclient /opt/hadoopclient/FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles
    If the following information is displayed, the configurations have been updated successfully:
    Succeed to refresh components client config.
Method 2:
  1. Log in to the node where the client is installed as user root.
  2. Go to the client installation directory, for example, /opt/client, and run the following commands to update the configuration file:
    cd /opt/client
    sh autoRefreshConfig.sh
  3. Enter the username and password of the FusionInsight Manager administrator and the floating IP address of FusionInsight Manager.
  4. Enter the names of the components whose configurations need to be updated. Use commas (,) to separate the component names. Press Enter to update the configurations of all components if necessary.
