Updated on 2025-11-25 GMT+08:00
Viewing a Health Check Task
Administrators can view all health check tasks in the health check management center to check whether the cluster is affected after the modification.
  2. Choose O&M > Health Check.
    By default, all saved health check reports are listed. The parameters for a health check report are as follows:
    Table 1 Parameters for a health check report
    Check Object
    Object to be checked. You can expand the list to view its details.
    Status
    Check result status. Value options are No problems found, Problems found, and Checking.
    Check Type
    Entity on which the check is to be performed. Value options are System, Cluster, Host, Service, and OMS. If you select Cluster, all items are checked by default.
    Start Mode
    Whether the health check is automatically or manually performed
    Started
    Start time of the check
    Completed
    End time of the check
    Operation
    Operations you can perform. Value options are Export Report and View Help.
    • In the upper right corner of the check list, you can filter health checks by check type or status.
    • If Check Type is Cluster, View Help is displayed in the Check Object drop-down list.
    • During a health check, the system determines whether check objects are healthy based on their historical monitoring metric data.
