Log Search
Follow the directions below to search logs by keyword and time range:
- On the LTS console, choose Log Management in the navigation pane on the left.
- In the log group list, click
on the left of a log group name.
- In the log stream list, click a log stream name.
- In the upper right corner, select a time range.
There are three types of time range: relative time from now, relative time from last, and specified time. Select a time range as required.
- From now: queries log data generated in a time range that ends with the current time, such as the previous 1, 5, or 15 minutes. For example, if the current time is 19:20:31 and 1 hour is selected as the relative time from now, the charts on the dashboard display the log data that is generated from 18:20:31 to 19:20:31.
- From last: queries log data generated in a time range that ends with the current time, such as the previous 1 or 15 minutes. For example, if the current time is 19:20:31 and 1 hour is selected as the relative time from last, the charts on the dashboard display the log data that is generated from 18:00:00 to 19:00:00.
- Specified time: queries log data that is generated in a specified time range.
- On the log stream details page, you can search for logs using the following methods:
- In the search area, click in the search box. The drop-down list contains the following items:
- Structured fields or index fields: Built-in fields are not displayed in the drop-down list. However, when you enter a built-in field, the drop-down list is automatically associated and matched with the field.
- NOT, AND, OR, :, and :* keywords can be displayed. Keywords other than NOT are displayed in the drop-down list only after you enter the keyword in the search box.
- When entering a keyword, you can press Tab to automatically add the first keyword displayed in the drop-down list.
- Keywords are case-insensitive.
- Historical records: A maximum of 20 historical records can be retained, but only the latest three records are displayed in the drop-down list.
- Quick search: quick search fields that have been created.
- Search syntax: common search syntax.
Enter a keyword, or select a field and keyword from the drop-down list, and click Query.
Logs that contain the keyword are displayed.
- Built-in fields include appName, category, clusterId, clusterName, collectTime, containerName, hostIP, hostIPv6, hostId, hostName, nameSpace, pathFile, podName and serviceID. By default, the fields are displayed in simplified mode, and hostIP, hostName, and pathFile are displayed at the beginning.
- The structured fields are displayed in key:value format.
- On the Raw Logs page, click a field in blue in the log content. You can select Copy, Add To Search, and Exclude from Search from the displayed drop-down list.
- Click a field for which quick analysis has been created to add it to the search box.
If the field you click already exists in the search box, it will be replaced by this newly added one. If the field is added for the first time, fields in the search box are searched using the AND operator.
- In the search area, press the up and down arrows on the keyboard to select a keyword or search syntax from the drop-down list, press Tab or Enter to select a keyword or syntax, and click Query.
Common Log Search Operations
Log search operations include sharing logs and refreshing logs.
Operation |
Description |
Creating quick search criteria |
Click |
Sharing logs |
Click |
Refreshing logs |
You can click
Copying logs |
Click |
Viewing context of a log |
Click |
Simplifying field details |
Click |
Unfold/Fold |
Click ![]() ![]() Unfold is enabled by default. |
Downloading logs |
Click Direct Download: Download log files to the local PC. Up to 5000 logs can be downloaded at a time. Select .csv or .txt from the drop-down list and click Download to export logs to the local PC.
Collapse all/Expand all |
Click By default, logs are not collapsed, and two rows of logs are shown after collapsing. You can display up to six rows. |
Layout |
Move the cursor over
JSON |
Move the cursor over Formatting is enabled by default. The default number of expanded levels is 2.
Invisible fields ( |
This list displays the invisible fields configured in the layout settings.
Syntax and Examples of Searching
Search syntax:
Filter |
Description |
Exact search by keyword |
LTS searches for logs containing the exact keyword (case-sensitive) that you specify. A keyword is the word between two adjacent delimiters. You can add an asterisk (*) after a keyword, for example, error*, if you are not familiar with delimiters. |
Exact search by phrase |
LTS searches for logs containing the exact phrase (case-sensitive) that you specify. |
Intersection of search results |
Union of search results |
AND |
and |
OR |
or |
NOT |
Logs that contain the keyword after NOT are excluded. |
not |
Logs that contain the keyword after not are excluded. |
Fuzzy search. The question mark (?) can be put in the middle or at the end of a keyword to replace a character. |
Search for structured long or float fields with values greater than a specified number. For example, num > 10. |
Search for structured long or float fields with values less than a specified number. For example, num < 10. |
Search for structured long or float fields with values equal to a specified number. For example, num = 10. |
Search for structured long or float fields with values greater than or equal to a specified number. For example, num >= 10. |
Search for structured long or float fields with values less than or equal to a specified number. For example, num <= 10. |
Search for a specified field (key:value). For example, request_method:GET. Use double quotation marks ("") to enclose a field name or value that contains reserved characters, such as spaces and colons (:). For example, "file info":apsara. |
Enclose a syntax keyword to convert it into common characters. For example, "and". This "and" means searching for logs that contain this word. It is not an operator. All words enclosed in double quotation marks ("") are considered as a whole. |
Escape double quotation marks (""). The escaped quotation marks indicate the symbol itself. For example, to search for instance_id:nginx"01", use instance_id:nginx\"01\". |
An asterisk (*) can be placed only after the keyword and can match zero, one, or multiple characters. For example, host:abcd*c. LTS will find 100 words that meet the search criteria in all logs and return these logs. |
in |
Query logs whose field values are in a specified range. Brackets indicate a closed interval, and parentheses indicate an open interval. Numbers are separated with spaces. Example: request_time in [100 200] and request_time in (100 200] Enter in in lowercase and use only long or float fields. |
Specify fields that should be matched with higher priority. Use and, or, and not to connect fields. Example: (request_method:GET or request_method:POST) and status:200 |
key:#"abc def" |
Search for specified field names and values (key:value) after field indexing is configured. |
#"abc def" |
Full text search. LTS splits an entire log into multiple words based on the delimiter you set. Search for logs using specified keywords (field name and value) and rules. |
Operators (such as &&, ||, AND, OR, NOT, *, ?, :, ", >, <, =, >=, and <=) contained in raw logs cannot be used to search for logs.
Search rules:
- Fuzzy search is supported.
For example, if you enter error*, all logs containing error will be displayed and those start with error will be highlighted.
- You can use a combination of multiple search criteria in the key and value format: key1:value1 AND key2:value2 or key1:value1 OR key2:value2. After entering or selecting key1:value1, you need to add AND or OR before entering or selecting key2:value2 in the search box.
- Click a keyword and select one of the three operations from the displayed drop-down list: Copy, Add To Search, and Exclude from Search.
Copy: Copy the field.
Add To Search: Add AND field: value to the search statement.
Exclude from Search: Add NOT field: value to the query statement.
Searching sample
- Search for logs containing start: Enter start.
- Search for logs containing start to refresh: Enter start to refresh.
- Search for the logs containing both keywords start and unexpected: Enter start && unexpected.
- Search for the logs containing both keywords start and unexpected: Enter start AND unexpected.
- Search for the logs containing keyword start or unexpected: Enter start || unexpected.
- Search for the logs containing keyword start or unexpected: Enter start OR unexpected.
- Log data that does not contain query1: NOT content: query1.
- error*: logs that contain error.
- er?or: logs that start with er, is followed by any single character, and end with or.
- If your keyword contains a colon (:), use the content: Keyword format. Example: content: "120.46.138.115:80" or content: 120.46.138.115:80.
- query1 AND query2 AND NOT content: query3: logs that contain both query1 and query2 but not query3.
- When you enter a keyword to query logs, the keyword is case-sensitive. Log contents you queried are case-sensitive but the highlighted log contents are case-sensitive.
- The asterisk (*) and question mark (?) do not match special characters such as hyphens (-) and spaces.
- For fuzzy match, the question mark (?) or asterisk (*) can only go in the middle or at the end of a keyword. For example, you can enter ER?OR or ER*R.
- When you search logs by keyword, if a single log contains more than 255 characters, exact search may fail.
