Step 5: Enable Database Audit
By default, database audit complies with a full audit rule, which is used to audit all databases that are connected to the database audit instance. You can enable audit and check audit results. For details, see Viewing the Audit Dashboard.
- You have added and installed an agent, and the agent status is Running.
- A security group rule has been configured for the database audit instance.
Enabling Database Audit
- Select a region, click  , and choose . The Dashboard page is displayed. , and choose . The Dashboard page is displayed.
- In the navigation tree on the left, choose Databases.
- Select a database audit instance from the Instance drop-down list.
- In the database list, click Enable in the Operation column of the database you want to audit.
    The Audit Status of the database is Enabled. You do not need to restart the database. Figure 1 Enabling database audit
Verifying Audit Results
- Run an SQL statement (for example, show databases) in the target database.
- Select a region, click  , and choose . The database audit service page is displayed. , and choose . The database audit service page is displayed.
- In the left navigation pane, choose Dashboard.
- In the navigation tree on the left, choose Data Reports. The Data Reports page is displayed.
- In the Instance drop-down list, select the instance that audits the target database.
- Click the Statements tab.
- Click  next to Time to set the start and end time, and click Submit.
    Figure 2 Viewing SQL statements next to Time to set the start and end time, and click Submit.
