Installing an Agent (Windows OS)
You can enable database audit only after the agent is installed. This topic describes how to install the agent on a node running a Windows OS. For details about how to install an agent on the Linux OS, see Installing an Agent (Linux OS).
- You have applied for a database audit instance and the Status is Running.
- You have added an agent to your database.
- You have obtained the agent installation package for the Windows OS.
- The Windows OS version of the target node is supported by the agent.
You can install the agent on the database or application side, depending on your database type and deployment scenario. Common database scenarios are as follows:
- Deploy DBSS for databases built on ECS/BMS. For details, see Figure 1 and Figure 2.
- Deploy DBSS for RDS databases. For details, see Figure 3 and Figure 4.
Table 1 describes where to install the agent in the preceding scenarios.
If your applications and databases (databases built on ECS/BMS) are deployed on the same node, install the agent on the database side.
Scenario |
Where to Install Agent |
Audit Scope |
Description |
Self-built database on ECS/BMS |
Database |
All access records of applications that have accessed the database |
RDS database |
Application side (if applications are deployed on the cloud) |
Access records of all the databases connected to the application |
RDS database |
Proxy side (if applications are deployed off the cloud) |
Only the access records between the proxy and database. Those between the applications and database cannot be audited. |
Install the agent on the proxy side. |
Installing an Agent
- Install Npcap on the Windows server.
- If Npcap has been installed on the Windows OS, go to 2.
- If the Npcap has not been installed on the Windows server, perform the following steps:
- Download the latest Npcap software installation package from https://nmap.org/npcap/.
Figure 5 Downloading Npcap
- Upload the npcap-xxxx.exe software installation package to the VM where the agent is to be installed.
- Double-click the Npcap installation package.
- In the displayed dialog box, click I Agree, as shown in Figure 6.
- In the displayed dialog box, leave all the check boxes unselected and click Install, as shown in Figure 7.
- In the displayed dialog box, click Next.
- Click Finish.
- Log in to the target Windows server as the Administrator user.
- Copy the downloaded .zip agent installation package to any directory on the server.
- Decompress the package.
- Double-click the install.bat file in the package directory.
- Press any key to complete installation after the output shown in Figure 8 is displayed.
- Check the installation result. If the dbss_audit_agent process can be found in the Windows Task Manager, the installation succeeded.
If it is not found, install the agent again.
