Managing Privacy Data Protection Rules
Updated on 2024-01-12 GMT+08:00
You can view, enable, edit, disable, or delete data masking rules.
You have applied for a database audit instance and the Status is Running.
Viewing Privacy Data Protection Rules
  2. Select a region, click , and choose Security > Database Security Service. The Dashboard page is displayed.
  3. In the navigation tree, choose Rules.
  4. In the Instance drop-down list, select an instance to view its privacy data protection rule.
  5. Click the Privacy Data Protection tab.
    Only user-defined rules can be edited and deleted. Default rules can only be enabled and disabled.
  6. View the rules. For details about related parameters, see Table 1.
    • Store Result Set
      You are advised to disable . After this function is disabled, database audit will not store the result sets of user SQL statements.
      Do not enable this function if you want to prepare for PCI DSS/PCI 3DS CSS certification.
    • Mask Privacy Data
      You are advised to enable . After this function is enabled, you can configure masking rules to prevent privacy data leakage.
    Figure 1 Masking rule information
    Table 1 Masking rule parameters
    Rule Name
    Rule name
    Rule Type
    Rule type.
    • Default
    • User-defined
    Regular Expression
    Regular expression that specifies the sensitive data pattern
    Substitution Value
    Value used to replace sensitive data specified by the regular expression
    Status
    Status of a rule. Its value can be:
    • Enabled
    • Disabled
    You can perform the following operations on a rule:
    • Disable
      Locate the row that contains the rule to be disabled and click Disable in the Operation column. A disabled rule cannot be used.
    • Edit
      Locate the row that contains the rule to be modified, click Edit in the Operation column, and modify the rule in the displayed dialog box.
    • Delete
      Locate the row that contains the rule to be deleted, click Delete in the Operation column, and click OK in the displayed dialog box.
