Viewing Operation Logs
This section describes how to view operation logs of a database audit instance.
You have applied for a database audit instance and the Status is Running.
- Select a region, click  , and choose . The Dashboard page is displayed. , and choose . The Dashboard page is displayed.
- In the navigation tree on the left, choose .
- Click the name of the instance whose operation logs you want to view. The Overview page is displayed.
- Click the Logs tab. The log list page is displayed.
- View operation logs, as shown in Figure 1. For details about related parameters, see Table 1.
      Select Last 30 minutes, 1 hour, 24 hours, 7 days, or 30 days, or click  to set start time and end time to view the operation logs of a specified time range. to set start time and end time to view the operation logs of a specified time range.Table 1 Parameters Parameter Description Username User who performs the operation Time Time when the operation was performed Function Function of the operation Action Action of the operation Operation Object Object of the operation Description Description of the operation Result Result of the operation
