Viewing SQL Statement Details
After connecting the database to the database audit instance, view SQL statements of the database.
- You have applied for a database audit instance and the Status is Running.
- Database audit has been enabled.
- Select a region, click
, and choose . The Dashboard page is displayed. - Click the Statements tab.
- View SQL statement information.
Figure 1 Querying SQL statements
To query a specified SQL statement, perform the following steps:
- Select All, Last 30 minutes, 1 hour, 24 hours, 7 days, or 30 days for Time and click
to view SQL statements of the specified time range. - Select All, High, Moderate, Low, or Trusted for Risk Severity and click
. SQL statements of specified severity are displayed in the list.
A maximum of 10,000 records can be retrieved in a query.
- In the row containing the desired SQL statement, click Details in the Operation column.
Figure 2 Viewing details of SQL statements
- View the SQL statement information in the Details dialog box, as shown in Figure 3. For details about related parameters, see Table 1.
The maximum length of an audit statement or result set is 10,240 bytes. Excessive parts are not recorded in audit logs.
Table 1 Parameters for details of SQL statements Parameter
Session ID
ID of an SQL statement, which is automatically generated
Database Instance
Database where an SQL statement is executed
Database Type
Type of the database where an SQL statement is executed
Database User
Database user for executing an SQL statement
Client MAC Address
MAC address of the client where an SQL statement is executed
Database MAC Address
MAC address of the database where an SQL statement is executed
Client IP Address
IP address of the client where an SQL statement is executed
Database IP Address/Domain Name
IP address or the domain name of the database where an SQL statement is executed
Client Port
Port of the client where an SQL statement is executed
Database Port
Port of the database where the SQL statement is executed
Client Name
Name of the client where an SQL statement is executed
Operation Type
Type of an SQL statement operation
Operation Object Type
Type of an SQL statement operation object
Response Result
Response by executing an SQL statement
Affected Rows
Number of rows affected by executing an SQL statement
Started
Time when an SQL statement starts to be executed
Ended
Time when the SQL statement execution ends
SQL Statement
Name of an SQL statement
Request Result
Result of requesting for executing an SQL statement
