Ingresses
Why We Need Ingresses
Services forward requests using layer-4 TCP and UDP protocols. Ingresses forward requests using layer-7 HTTP and HTTPS protocols. Domain names and paths can be used to achieve finer granularities.
Ingress Working Mechanism
To use ingresses, you must install Ingress Controller on your Kubernetes cluster. Ingress Controller can be implemented in multiple modes. The most common one is NGINX Ingress Controller maintained by Kubernetes. CCE works with Elastic Load Balance (ELB) to implement layer-7 load balancing (via ingresses).
An external request is first sent to Ingress Controller. Then, Ingress Controller locates the corresponding Service based on the routing rule of an ingress, queries the IP address of the pod through the Endpoint, and forwards the request to the pod.
Creating an Ingress
apiVersion: networking.k8s.io/v1beta1
kind: Ingress
annotations:
kubernetes.io/ingress.class: cce
kubernetes.io/elb.port: '8080'
kubernetes.io/elb.ip: 192.168.10.155
kubernetes.io/elb.id: aa7cf5ec-7218-4c43-98d4-c36c0744667a
rules:
- host: ''
http:
paths:
- backend:
serviceName: nginx
servicePort: 8080
path: "/test"
property:
You can also set the external domain name in an ingress so that you can access the load balancer through the domain name and then access backend Services.
Domain name-based access depends on domain name resolution. You need to point the domain name to the IP address of the load balancer. For example, you can use Domain Name Service (DNS) to resolve domain names.
rules:
- host: www.example.com # Domain name
http:
paths:
- path: /
backend:
serviceName: nginx
servicePort: 80
Accessing Multiple Services
An ingress can access multiple Services at the same time. The configuration is as follows:
- When you access http://foo.bar.com/foo, the backend Service s1:80 is accessed.
- When you access http://foo.bar.com/bar, the backend Service s2:80 is accessed.
rules:
- host: foo.bar.com # Host address
http:
paths:
- path: "/foo"
backend:
serviceName: s1
servicePort: 80
- path: "/bar"
backend:
serviceName: s2
servicePort: 80
