Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Service
When using a LoadBalancer Service, you can configure a trustlist or blocklist to specify the IP addresses that are allowed or denied to access a load balancer listener.
- Trustlist: Only the IP addresses in the list can access the listener.
- Blocklist: The IP addresses in the list are not allowed to access the listener.
- A Kubernetes cluster is available and the cluster version meets the following requirements:
- v1.23: v1.23.12-r0 or later
- v1.25: v1.25.7-r0 or later
- v1.27: v1.27.4-r0 or later
- v1.28: v1.28.2-r0 or later
- Other clusters of later versions
- An IP address group has been created on the ELB console.
Using the CCE Console
- Choose Services & Ingresses in the navigation pane, click the Services tab, and click Create Service in the upper right corner.
- Configure Service parameters.
- Service Name: Enter a service name, for example, service-acl.
- Service Type: Select LoadBalancer.
- Service Affinity: Select cluster level or node level as needed. For details about the differences, see externalTrafficPolicy (Service Affinity).
- Selector: Add a label and click Confirm. The Service will use this label to select pods. You can also click Reference Workload Label to use the label of an existing workload. In the dialog box that is displayed, select a workload and click OK.
- Load Balancer
Select a load balancer to be accessed. Only load balancers in the same VPC as the cluster are supported. If no load balancer is available, click Create Load Balancer to create one on the ELB console. Alternatively, select Auto create to create a load balancer. For details about parameter settings, see Table 1.
- Health Check: defaults to Global health check. You can configure this parameter as needed.
- Ports
- Protocol: protocol used by the Service.
- Service Port: port used by the Service. The port number ranges from 1 to 65535.
- Container Port: listener port of the workload. For example, Nginx uses port 80 by default.
- Access Control
- Inherit ELB Configurations: CCE does not modify the existing access control configurations on the ELB console.
- Allow all IP addresses: No access control is configured.
- Trustlist: Only the selected IP address group can access the load balancer.
- Blocklist: The selected IP address group cannot access the load balancer.
- Click OK.
Using kubectl
apiVersion: v1 kind: Service metadata: name: nginx annotations: kubernetes.io/elb.id: <your_elb_id> # Load balancer ID. Replace it with the actual value. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.acl-id: <your_acl_id> # ID of an IP address group for accessing a load balancer kubernetes.io/elb.acl-status: 'on' # Enable access control. kubernetes.io/elb.acl-type: 'white' # Trustlist for access control spec: selector: app: nginx ports: - name: service0 port: 80 protocol: TCP targetPort: 80 type: LoadBalancer
Parameter |
Type |
Description |
kubernetes.io/elb.acl-id |
String |
kubernetes.io/elb.acl-status |
String |
This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
kubernetes.io/elb.acl-type |
String |
