Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ Network/ Ingresses/ Nginx Ingresses/ Configuring an HTTPS Certificate for an Nginx Ingress
HTTPS certificates can be configured for ingresses to provide security services.
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Ingress supports two TLS secret types: kubernetes.io/tls and IngressTLS. IngressTLS is used as an example. For details, see Creating a Secret. For details about examples of the kubernetes.io/tls secret and its description, see TLS secrets.
    Create a YAML file named ingress-test-secret.yaml. The file name can be customized.
    vi ingress-test-secret.yaml
    The YAML file is configured as follows:
    apiVersion: v1
    data:
      tls.crt: LS0******tLS0tCg==
      tls.key: LS0tL******0tLS0K
    kind: Secret
      annotations:
        description: test for ingressTLS secrets
      namespace: default
    type: IngressTLS
    In the preceding information, tls.crt and tls.key are only examples. Replace them with the actual files. The values of tls.crt and tls.key are Base64-encoded.
  3. Create a secret.
    kubectl create -f ingress-test-secret.yaml
    If information similar to the following is displayed, the secret has been created:
    secret/ingress-test-secret created
    View the created secret.
    kubectl get secrets
    NAME                         TYPE                                  DATA      AGE
    ingress-test-secret          IngressTLS                            2         13s
  4. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    For clusters of v1.23 or later:
    kind: Ingress
      namespace: default
      tls:
      - hosts:
        - foo.bar.com
        secretName: ingress-test-secret  # Replace it with your TLS key certificate.
      rules:
        - host: foo.bar.com
          http:
            paths:
              - path: /
                backend:
                  service:
                    name: <your_service_name>  # Replace it with the name of your target Service.
                    port:
                      number: <your_service_port>  # Replace it with the port number of your target Service.
                property:
      ingressClassName: nginx
    For clusters of v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      annotations:
        kubernetes.io/ingress.class: nginx
      tls:
      - hosts:
        - foo.bar.com
      rules:
      - host: foo.bar.com
        http:
          paths:
          - path: '/'
            backend:
              serviceName: <your_service_name>  # Replace it with the name of your target Service.
              servicePort: <your_service_port>  # Replace it with the port number of your target Service.
  5. Create an ingress.
    If information similar to the following is displayed, the ingress has been created.
    ingress/ingress-test created
    View the created ingress.
    kubectl get ingress
    If information similar to the following is displayed, the ingress has been created and the workload is accessible.
    NAME             HOSTS     ADDRESS          PORTS   AGE
    ingress-test     *         121.**.**.**     80      10s
  6. Enter https://121.**.**.**:443 in the address box of the browser to access the workload (for example, Nginx workload).
    121.**.**.** indicates the IP address of the unified load balancer.
