Creating a Disk Backup Vault
This section describes how to create a disk backup vault.
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery.
- In the navigation pane, choose Cloud Disk Backups.
- In the upper right corner of the page, click Create Disk Backup Vault.
- (Optional) In the disk list, select the disks you want to back up. After disks are selected, they are added to the list of selected disks.
- The selected disks must have not been associated with any vault and must be in the Available or In-use state.
- You can also associate disks with the vault you are creating later if you skip this step.
- Specify the vault capacity. This capacity is the total space that is required by the disks you want to associate with this vault. Plan the vault capacity and ensure that it is at least the same as the size of the disks you want to back up. If a backup policy is applied to the vault, plan more capacity as required. The capacity ranges from 10 GB to 10,485,760 GB.
You can expand the vault capacity if it becomes insufficient.
- Configure auto backup.
- If you select Configure, you must then select an existing backup policy or create a policy. After the vault is created, CBR will apply the policy to this vault, and all disks associated with this vault will be automatically backed up based on this policy.
- If you select Skip, disks associated with this vault will not be automatically backed up until you apply a backup policy to the vault.
- Specify a name for the vault.
The name can contain 1 to 64 characters. Only letters, digits, underscores (_), or hyphens (-) are allowed. Example: vault-612c.
You can also use the default name vault_xxxx.
- Complete the creation as prompted.
- Go back to the Cloud Disk Backups page. You can see the created vault in the vault list.
You can associate disks to the new vault or perform backup for the disks. For details, see Vault Management.
