Updated on 2025-07-04 GMT+08:00
Application Schedule
- Immediate: The rule takes effect immediately after it is enabled.
- Periodic: You can set a time range on each time in a specific time zone to let the rule work periodically.
- Gray release: In the specified period, the probability that client requests trigger the rule increases linearly from 0% to 100%.
- Custom: The rule takes effect in a time range you specify.
