Updated on 2025-08-05 GMT+08:00
Protective Action
The protective action you specify here is only used for this rule.
  • Verification code: WAF allows requests that trigger the rule as long as your website visitors complete the required verification.
    The cloud load balancer access mode does not support this protective action.
  • Block: WAF blocks requests that trigger Rate Limit set in the rule.
  • Block dynamically: WAF blocks requests that trigger the rule based on Allowable Frequency, which you configure after the first rate limit period is over.
  • Log only: WAF only logs requests that trigger Rate Limit set in the rule.
  • JS Challenge: WAF returns a piece of JavaScript code that can be automatically executed by a normal browser to the client. If the client properly executes the JavaScript code, WAF allows all requests from the client within a period of time (30 minutes by default). During this period, no verification is required. If the client fails to execute the code, WAF blocks the requests.
    • The cloud load balancer access mode does not support this protective action.
    • If the referer in the request is different from the current host, the JS challenge does not work.
