Bandwidth (Mbit/s)
Parameter Bandwidth (Mbit/s) is available only when Billed By is set to Bandwidth or Traffic.
You can select or specify a maximum bandwidth size on the console. A bandwidth can be from 1 Mbit/s to 2,000 Mbit/s.
Currently, you are only billed for the outbound bandwidth you use.
- If your purchased bandwidth is less than or equal to 10 Mbit/s, the inbound bandwidth will be 10 Mbit/s, and the outbound bandwidth will be the same as the purchased bandwidth.
- If your purchased bandwidth is greater than 10 Mbit/s, both the outbound and inbound bandwidths will be the same as the purchased bandwidth.
The preceding bandwidth limit is not applicable in regions CN North-Beijing1 and CN East-Shanghai2.
FAQ
