EIP Type
- Dynamic BGP
Dynamic BGP provides automatic failover and chooses the best path based on the real-time network conditions and preset policies. The BGP public network egress supports switchover across domains within seconds, providing your users with high-speed and secure networks.
This option works well for workloads that require higher network stability and connectivity, such as financial transactions, online games, large-scale enterprise applications, and livestreaming services.
- Static BGP
Static BGP is a more cost-effective option that allows resources to access the Internet over a single carrier network. Static routes are configured manually and must be reconfigured manually anytime the network topology or link status changes.
This is a more cost-effective option that is a great fit for workloads that are running in relatively stable networks and have disaster recovery setups.
- Premium BGP
BGP is used to interconnect with lines of multiple mainstream carriers. Public network connections that feature low latency and high quality are directly established between Chinese mainland and Hong Kong (China). Premium BGP chooses the optimal path for access from the abroad and allows users in the Chinese mainland to access cross-border applications faster.
Premium BGP is now available only in the CN-Hong Kong region.
- EIP Pool
Parameter EIP Pool is available only when Billing Mode is set to Pay-per-use. An EIP pool helps you manage a large number of EIPs and assigns EIPs with dynamic BGP routing, ensuring network stability and excellent user experience. For details, see EIP Pool Overview.
FAQ
