Event QPS
It controls the QPS for limiting event creations. The default value is 5. If the parameter is set to 0, there is no QPS limit for event creations.
Value Range
Greater than or equal to 0
Default Value
5
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Keep the default of 5.
