Preemptive Scheduling
It controls whether to enable preemptive scheduling. Preemption scheduling is performed for tasks with higher priorities in the same queue based on priority rules.
If preemption scheduling is enabled when cluster resources are insufficient, high-priority jobs will evict low-priority jobs.
Value Range
true or false
Default Value
false
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Either preemption scheduling or delayed pod creation can be enabled, but not both.
