Minimum Number of Container Network Interfaces Bound to a Node
It specifies the minimum number of container network interfaces bound to a node. The value can be a number or a percentage.
The value is a positive integer. The default value 10 indicates that there are at least 10 container network interfaces bound to a node. If the number you entered exceeds the container network interface quota of the node, the network interface quota will be used.
Value Range
0 to 256
Default Value
10
Modifiable
Yes
Scope
CCE Turbo clusters
Suggestions
Set the parameter to the number of pods running on most nodes. Some network interfaces will be pre-bound to nodes based on the configured value, and IP addresses will be allocated to them from the container subnet. Therefore, properly plan container CIDR blocks.
