Help Center/ Cloud Container Engine/ Drawer/ Configuration Reference/ Cluster/ Network/ Upper Limit of Pre-bound Container ENIs
Updated on 2025-06-13 GMT+08:00
When the number of container ENIs bound to a node exceeds what is supported, no more container ENIs will be pre-bound. Checking the maximum number of pre-bound container ENIs is enabled only when the value of this parameter is at least equal to the minimum number of container ENIs (nic-minimum-target) bound to a node.
The value must be a positive integer. The default value of 0 specifies that the check on the maximum number of container ENIs pre-bound to a node is disabled. If the number you entered exceeds the container ENI quota of the node, the ENI quota will be used.
Value Range
From 0 to 256
Default Value
0
Modifiable
Yes
Scope
CCE Turbo clusters
Suggestions
To configure the upper limit, set the parameter to the maximum number of pods that can run on most nodes.
