Unrestricting Purchases
As a reseller, once your associated distributor grants you the purchase restriction and budget setting permissions, you can unrestrict purchases for your customers.
- Sign in to Huawei Cloud as a partner.
- In the drop-down list of your account name, click Partner Center to go to the Partner Center.
- In the top navigation bar, choose Sales > Customers > Customer Management.
- In the customer list, select a customer and click Unrestrict Purchase in the Operation column.
- In the dialog box that is displayed, enter the reason and click OK. The system displays a message indicating that the restriction is canceled successfully.
If you have enabled the verification code function, a verification code will be required.
