Billing of In-use Resource Unsubscription
Unsubscription Rules for Yearly/Monthly Subscriptions
- When unsubscribing from resource instances, you will be billed handling fees. If the instances are in use, the consumption amount will also be billed. The used coupons will not be returned.
- The consumption amount and unsubscription handling fee refer to the cash used.
- The formula for calculating the unsubscription fee is for reference only. The actual amount depends on the bill and expenditure details.
- Actual refund amount = Actual payment – Consumption amount – Handling fee (If the calculated refund amount is less than 0, there will be no refund.)
- Actual payment refers to the payment you actually made, excluding any payment in cash coupons.
- Consumption amount = Actual payment x (Actual usage period/Subscribed period) (The usage duration is accurate to hour.) For unsubscriptions, the actual usage period and subscribed period are rounded down by hour.
- Subscribed period: calculated from the hour when the order takes effect. For example, if a resource is purchased at 10:30, the total order duration starts from 10:00.
- Actual usage period: The actual duration is calculated based on the hour when the unsubscription is performed. For example, if a resource is unsubscribed from at 18:40, the actual usage period is calculated starting from 18:00.
Example: If you purchased a monthly EVS disk at 10:30:00 on January 1, 2024, and it would expire at 23:59:59 on February 1, 2024. The total order duration is 31 days and 14 hours (from 10:00:00 on January 1, 2024 to 2024 00:00:00 on February 2, 2024). At 18:40:00 on January 15, 2024, you unsubscribed from the resource. The actual usage period was 14 days and 8 hours (from 10:00:00 on January 1, 2024 to 18:00:00 on January 15, 2024).
- Handling fee: There is a handling fee for unsubscription, unless the free handling fee is specified in the effective framework contract for the customer.
The handling fee depends on the actual usage duration and subscription term, as shown in Table 1.
Table 1 Unsubscription handling fee Subscription Term
Actual Usage Duration ≤ 1 Year
1 Year < Actual Usage Duration ≤ 2 Years
2 Years < Actual Usage Duration ≤ 3 Years
3-year subscription
Handling fee = 15% of your actual payment
Handling fee = 10% of your actual payment
Handling fee = 5% of your actual payment
2-year subscription
1-year subscription
Monthly subscription
Example 1: Unsubscribing from a resource which is not renewed
At 10:30:00 on January 1, 2024, you purchased a monthly EVS disk. The EVS would expire at 23:59:59 on February 1, 2024. The subscribed period is 31 days and 14 hours (including the hour when the order takes effect). The amount due was $90.00 USD. You used a cash coupon of $10 USD, and the actual payment was $80.00 USD.
At 18:40:00 on January 8, 2024, you unsubscribed from the resource. The refund is as follows:
- The actual usage period was 7 days and 8 hours (excluding the hour when the unsubscription was performed).
- Consumption amount = Actual usage period/Subscribed period x Actual payment = 7 days and 8 hours/31 days and 14 hours x $80 USD = $18.57 USD
- Handling fee = Actual payment x Handling fee ratio = 80 x 10% = $8 USD
Refund amount = Actual payment ($80.00 USD) – Amount due ($18.57 USD) – Handling fee ($8.00 USD) = $53.43 USD
Example 2: Unsubscribing from a resource which has been renewed
At 10:30:00 on March 1, 2024, you subscribed to an ECS for three months. The ECS would expire at 23:59:59 on June 1, 2024. The subscribed period is 92 days and 14 hours (including the hour when the order takes effect). The amount due is $300.00 USD and the actual payment is $300.00 USD.
On March 21, 2024, you spent $100.00 USD in renewing the ECS for one month, and the resource would expire on July 1, 2024. You actually paid $100.00 USD.
At 18:40:00 on April 1, 2024, you unsubscribed from the ECS. The refund is as follows:
The actual usage duration was 31 days and 8 hours (excluding the hour when the unsubscription was performed).
Consumption amount = Actual usage period/Subscribed period x Actual payment = 31 days and 8 hours/92 days and 14 hours x $300 USD = $101.53 USD
Handling fee = Actual payment x Handling fee ratio = 300 x 10% = $30 USD
Refund amount = Actual payment for the purchase ($300 USD) – Consumption amount ($101.53 USD) – Handling fee ($30 USD) + Actual payment for the renewal ($100 USD) = $268.47 USD
Unsubscription Rules for Reserved Instances
Table 2 describes the calculation formulas of refunds for reserved instances and the payment modes. See the unsubscription page for the final refund amount.
Full Upfront |
No Upfront |
Fee |
Remaining value – Handling fee |
Handling fee |
Remaining value |
Cash x Remaining period/Total period |
Unsubscription handling fee |
Prepaid amount (= Cash + Cash coupons) x Remaining period/Total period x 12% |
Amount per hour x Total subscribed hours x Remaining period/Total period x 12% |
Calculation formula |
Cash x Remaining period/Total period – Prepaid amount (= Cash + Cash coupons) x Remaining period/Total period x 12% (Cleared when the unsubscribed amount is less than 0) |
Payment method |
Money returned to customers by Huawei is paid immediately upon unsubscription. |
Payment to Huawei from customers is settled monthly. Coupons dedicated for RIs can be used if there are. |
- Used coupons will not be returned when you unsubscribe from an all-upfront reserved instance.
- Order amount = Prepaid amount (= Cash + Cash coupons) + Amount per hour x Total subscribed hours.
- Unsubscription handling fee = Order amount x Remaining period/Total period x 12%. For a no-upfront reserved instance, the handling fee is deducted based on the following order of priority: Cash coupons > Balance.
- Remaining period: The remaining valid hours starting from the next hour. For example, if the unsubscription occurs at 10:30, the remaining period is calculated starting from 11:00.
- For an all-upfront reserved instance, if the calculated refund amount is less than 0, it is cleared and no payment is needed from the customer.
Example 1
Suppose you purchased a 1-year reserved instance and paid $100 USD ($50 USD cash coupon + $50 USD balance) in advance. Half a year later, you want to unsubscribe from the reserved instance. The remaining value of the reserved instance is $25 USD and the handling fee is $6 USD. In this case, an actual refund of $19 USD is all returned to the account balance.
Example 2:
Suppose you purchased a 1-year reserved instance and paid $100 USD ($90 USD cash coupon + $10 USD balance) in advance. Half a year later, you want to unsubscribe from the reserved instance. The remaining value of the reserved instance is $5 USD and the handling fee is $6 USD. In this case, the refund amount is less than $0 USD, no refund will be returned and no payment is required from the customer.
- Go to the Unsubscriptions page in the Billing Center.
- Choose Unsubscribe from In-Use Resources > Unsubscription Allowed.
- Unsubscribe from a single instance or multiple instances in a batch based on the actual requirements.
- You can search for instances by instance name, order number, or ID, or filter instances by product type, region, or enterprise project. Only when the enterprise project management function is enabled, you can filter instances by enterprise project.
- If you unsubscribe from instances in a batch, a combined transaction order is generated. On the combined order details page, click the order number of an instance to view the detailed unsubscription and refund of the instance.
- Single unsubscription: Click Unsubscribe from Resource in the Operation column for the instance which you want to unsubscribe from.
- Batch unsubscription: Select the target instances from the list and click Batch Unsubscribe on top of the list.
- View the unsubscription information and refunds. Select the unsubscription reasons, select the confirmation checkbox, and then click Confirm.
In the unsubscription from a composite product (for example, ECS + image + EVS), of which some are provided by Huawei Cloud and others by a third party, Huawei Cloud refunds you only the fees for the products charged by itself. You need to contact the specific service provider for the refund details.
