What Should I Do If an Error Is Reported When I Change Images for ECS Resources in Batches?
Issue Description
When changing image for batch ECS resources, "code":"Ecs.0021","message":"Failed to check Cinder quotas because the number of Gigabytes exceeded the upper limit." or CreateRootVolumeTask-fail: call evs api - create volume fail :{"error_msg":"volume gigabytes exceeded volume gigabytes quota!","common_error_code":"CMM.3141","error_code":"EVS.1042"} is displayed.
Solution
If the EVS disk quota is insufficient, apply for a higher EVS disk quota. For details, see Increasing EVS Resource Quotas.
