Help Center/
Cloud Operations Center/
FAQs/
Patch Management FAQs/
What Can I Do If "lsb_release not found" Occurs During Patch Operations?
Updated on 2025-09-11 GMT+08:00
Issue Description
The error message "lsb_release not found" is displayed during patch operations.
Solution
Check whether the lsb_release command package exists on the ECS instance.
- If no, install the command package.
- If the ECS instance contains the lsb_release command package, check whether the UniAgent version is later than 1.1.0. If yes, downgrade the UniAgent version to a version earlier than 1.1.0 and try again.
