- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
- Click the button for viewing the summary of the compliance report that reports non-compliance.
Figure 1 Viewing the compliance report summary
- View the status of the non-compliant patch and view different solutions based on the compliance status.
Table 1 Solutions for different compliance statuses Non-compliance Status
Solution
Failed
View the log of the patch service ticket that generates the compliance report and rectify the fault based on the failure log.
Installed-to be restarted
A newly installed patch can only take effect after the host is restarted. Therefore, you need to restart the host.
Rejected
If a patch is rejected in the patch baseline, the compliance report shows that the patch is rejected. To cancel the rejection, edit the corresponding baseline in the patch baseline.
