Help Center/ Cloud Operations Center/ FAQs/ Product Consultation/ What Can I Do If the Message "The number of agencies has reached the maximum!" Is Displayed When I Enable COC?
Updated on 2026-09-18 GMT+08:00
Symptom
When enabling COC, the error message "The number of agencies has reached the maximum!" is displayed.
Cause Analysis
The number of agencies exceeds the quota. When you enable COC, the system automatically creates the agency ServiceAgencyForCOC for you and completes authorization. If there is no remaining IAM agency quota, COC fails to be enabled and the error message is displayed.
Solution
  1. Log in to the IAM console.
  2. In the navigation pane on the left, choose Agencies.
  3. View the number of agencies that you can create.
    Figure 1 Viewing the number of agencies that you can create
  4. If there is no quota, perform one of the following operations as required.
    • Apply for a higher quota. For details, see Quota Adjustment.
    • Delete an agency that is no longer required.
      After you delete an agency, all permissions granted to the delegated account will be cancelled.
      Figure 2 Deleting a single agency
      Figure 3 Deleting agencies in batches
