How Do I Control Permissions Using Enterprise Projects?
Issue Description
Using enterprise projects to control permissions for COC is required.
Solution
- Log in to IAM as an administrator.
- Choose Permissions > Policies/Roles and click Create Custom Policy.
Figure 1 Creating a custom policy
- Set the policy content, select CloudOpsCenter, and select the operations you want to authorize by enterprise project. Click OK.
Figure 2 Setting the policy content (1)Figure 3 Setting the policy content (2)Figure 4 Setting the policy content (3)
Currently, only some COC operations can be authorized by enterprise project. For details about how to create custom policies, see Table 1.
Table 1 Operations that can be authorized by enterprise project Operation
coc:instance:reinstallOS
Grants permission to reinstall the ECS OS.
coc:instance:changeOS
Grants permission to change the ECS OS.
coc:instance:start
Grants permission to start an ECS.
coc:instance:reboot
Grants permission to restart an ECS.
coc:instance:stop
Grants permission to stop an ECS.
coc:instance:startRDSInstance
Grants permission to enable an RDS DB instance.
coc:instance:stopRDSInstance
Grants permission to stop an RDS DB instance.
coc:instance:restartRDSInstance
Grants permission to reboot an RDS DB instance.
coc:instance:scanOSCompliance
Grants the permission to scan server OS patches.
coc:instance:installPatches
Grants permission to install patches for an ECS.
coc:instance:executeDocument
Grants permission to execute documents on an ECS.
coc:schedule:create
Grants permission to create a scheduled task list.
coc:schedule:update
Grants permission to update a scheduled task.
- Select a user or user group for authorization as the administrator.
Figure 5 Selecting an object for authorization.
- Select the custom policy created in step 3. When setting the minimum authorization scope, specify enterprise project resources.
Figure 6 Granting permissions by enterprise project
