Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HDFS/ HDFS O&M Management/ Logging In to the HDFS Web UI to Check Component Status
Updated on 2025-11-13 GMT+08:00
You can log in to the HDFS web UI to check the Hadoop cluster status, node information, and HDFS information.
Notes and Constraints
By default, the admin user does not have the permissions to manage other components. If the page cannot be opened or the displayed content is incomplete when you access the native UI of a component due to insufficient permissions, you can manually create a user with the permissions to manage that component.
You have created a user who has the permissions to manage HDFS. For how to create a user with the permissions, see Creating an HDFS Role.
Accessing the HDFS Web UI
  1. Log in to Manager as a user who has the permissions to manage HDFS.
    For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
  2. Choose Cluster > Services > HDFS.
  3. In the Basic Information area, click NameNode(xxx,Active) to go to the HDFS web UI.
  4. On the HDFS web UI, click the tabs on the menu bar to view related information.
    For details about the related pages, see HDFS Web UI.
    Figure 1 HDFS web UI
HDFS Web UI
  • Overview: On the Overview tab, you can view the basic information about HDFS.
    • Overview: The Overview module on the Overview tab displays the overview information about the Hadoop cluster.
      Figure 2 Overview information about the Hadoop cluster
      The following table describes the common parameters.
      Table 1 Parameters on the Overview module
      Example Value
      Namespace
      NameService name of the current NameNode
      hacluster
      Namenode ID
      Unique ID of the current NameNode, which is used to distinguish different NameNodes.
      4
      Started
      Start time of the NameNode service
      Thu Jun 19 14:37:35 +0800 2025
      Version
      Hadoop version
      3.3.1-xxx
      Compiled
      Time when the Hadoop code is compiled, compiler, and compilation environment
      Sat Jan 14 04:02:00 +0800 2023 by root from (HEAD detached at 6e9ca6ee55)
      Cluster ID
      Unique ID of the HDFS cluster, which is used to distinguish different HDFS clusters.
      myhacluster
      Block Pool ID
      Unique ID of the HDFS block pool
      BP-xxx
    • Summary: displays the HDFS memory usage.
      Figure 3 HDFS memory usage
      Table 2 Parameters on the Summary module
      Example Value
      Security
      Whether to enable Kerberos authentication for the cluster
      Security is on.
      Safemode
      Whether to enable the security mode for NameNode.
      Safemode is off.
      Configured Capacity
      Total storage capacity of the cluster
      1.55 TB
      Configured Remote Capacity
      Remote storage capacity
      0 B
      DFS Used
      Total used storage space of the HDFS cluster
      8.82 GB (0.55%)
      Non DFS Used
      Storage space that is not used by HDFS in the HDFS cluster
      0 B
      DFS Remaining
      Remaining available storage space in the HDFS cluster
      1.54 TB (99.35%)
      Block Pool Used
      Used space and percentage of the block pool
      1.54 TB (99.35%)
      DataNodes usages% (Min/Median/Max/stdDev)
      Minimum, median, maximum, and standard deviation of DataNode usage
      0.55% / 0.55% / 0.55% / 0.00%
    • NameNode Journal Status: displays the status of NameNode logs.
      Figure 4 NameNode log status
    • NameNode Storage: displays information such as the storage path, type, and status of the NameNode.
    • DFS Storage Types: displays HDFS storage type information.
  • Datanodes
    On the Datanodes tab, you can view the information and status of data nodes.
    Figure 5 Datanodes information
    • Datanode usage histogram: displays the disk usage histogram of each DataNode.
    • In operation: displays details about each DataNode.
  • Datanodes Volume Failures
    This page displays information about data volume faults.
    Figure 6 Datanodes Volume Failures
  • Snapshot
    This page displays the Hadoop snapshot table directories and snapshot information.
    Figure 7 Snapshot
  • Startup Progress
    This page displays the Hadoop startup progress.
    Figure 8 Startup Progress
  • Utilities
    You can click the drop-down list to view HDFS file system, logs, and configurations.
    Figure 9 Utilities
    You can click Browse the file system to view file system information in the cluster.
    Figure 10 Browse the file system
  • Logout
    You can click Logout to exit the HDFS web UI.
Helpful Links
