What Can I Do If the Time of CCE Nodes Is Not Synchronized with the NTP Server?
Symptom
In special scenarios, if the ntpd on a node cannot access the NTP server for a long time, the time offset may be too large and cannot be automatically restored.
Problem Detection
You can detect the problem by installing the CCE Node Problem Detector add-on that has the node time synchronization check items. For details, see CCE Node Problem Detector.
Possible Cause
This is a known issue on nodes running EulerOS or CentOS. Nodes running other types of OSs are not affected by this issue.
This issue has been resolved in clusters of v1.19.16-r7, v1.21.9-r10, and v1.23.7-r10.
Solution
- If your cluster version is v1.19.16-r7, v1.21.9-r10, v1.23.7-r10, or later, the clock of the nodes in such clusters has been configured with chronyd for proper time synchronization. In this case, you can reset the nodes to rectify the fault.
- If your cluster version does not meet the requirements, you are advised to upgrade the cluster to v1.19.16-r7, v1.21.9-r10, v1.23.7-r10, or later, and then reset the nodes.
