Help Center/ Cloud Container Engine/ FAQs/ Node/ Node Running/ What Can I Do If a Tunnel Network Becomes Unavailable After yum update Is Used to Upgrade the OS?
Updated on 2026-01-05 GMT+08:00
The CCE console does not support node OS upgrades. You are advised not to upgrade the OS using yum update. You are advised to upgrade the OS by resetting the node.
If you upgrade the OS on a node in a cluster using yum update and restart the node, openvswitch used by the container tunnel network becomes unavailable.
Perform the following operations to restore the container network:
  1. Log in to the faulty node.
  2. Run the following script as root:
    #!/bin/bash
    function upgrade_openvswitch()
        cd /opt/cloud/cce/package/node-package
        openvswitch_pkg=$(ls canal-agent*.tgz | tail -n 1)
        tar -xzf $openvswitch_pkg
        cd canal-agent/package
        tar -xzf openvswitch*
        cd openvswitch
        bash can_ovs.sh update
    upgrade_openvswitch
