Help Center/
Cloud Container Engine/
FAQs/
Cluster/
Cluster Creation/
Why Can't I Create a CCE Cluster?
Updated on 2026-01-05 GMT+08:00
Overview
This section describes how to locate and rectify the fault if you fail to create a CCE cluster.
Details
Possible causes:
- The Network Time Protocol daemon (ntpd) is not installed or failed to be installed, Kubernetes components fail to pass the pre-verification, or the disk partition is incorrect. The current solution is to create a cluster again. For details about how to locate the fault, see Locating the Failure Cause.
- The cluster does not have sufficient underlying resources. You can create a new cluster with the appropriate type and scale.
- Check whether your account is in arrears. If so, you cannot purchase resources, including using cash coupons. For details, see Topping Up an Account (Prepaid Direct Customers).
View the cluster logs to identify the cause and rectify the fault.
- Log in to the CCE console and click Operation Records above the cluster list to view operation records.
- Click the record of the Failed status to view error information.
Figure 1 Viewing the operation details
- Rectify the fault based on the error information and create a cluster again.
