Help Center/ Cloud Container Engine/ FAQs/ Billing/ How Do I Unsubscribe from CCE?
Updated on 2026-06-26 GMT+08:00
Yearly/Monthly CCE resources can be unsubscribed from, including both the renewed and currently used parts. You cannot use these resources after unsubscription. A handling fee will be charged for unsubscribing from a resource.
Notes
  • Unsubscribing from CCE resources involves the renewed resources and the resources that are being used. After the unsubscription, these resources become unavailable.
  • Solution portfolios can only be unsubscribed from as a whole.
  • If an order contains resources in a primary-secondary relationship, you need to unsubscribe from the resources separately.
  • For details about unsubscribing from resources, see Unsubscription Rules.
  • Before requesting an unsubscription, ensure that you have migrated or backed up any data saved on CCE resources that will be unsubscribed from. After the unsubscription is complete, CCE resources and the data contained will be permanently deleted.
  • The middle of the unsubscription page displays a message showing the number of unsubscriptions you have performed and the remaining allowed number.
  1. Enter the Unsubscriptions page.
  2. Click the Unsubscribe from In-Use Resources tab.
  3. Unsubscribe from a single resource or from resources in a batch.
    • To unsubscribe from a single resource, click Unsubscribe from Resource in the row of the target resource.
      Figure 1 Unsubscribing from a single resource
    • To unsubscribe from resources in a batch, select the target resources from the list and click Batch Unsubscribe above the list.
      Figure 2 Unsubscribing from resources in a batch
  4. On the Unsubscribe from In-Use Resources page, confirm the information, select a reason for the unsubscription, and click Confirm.
