- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
On this page
Show all
Help Center/
Cloud Container Engine_Autopilot/
FAQs/
Workloads/
Workload Exceptions/
What Do I Do If an Image Can't Be Pulled from SWR During Workload Creation?
Symptom
The following information is displayed when a workload is created in a CCE Autopilot cluster:
Failed to pull image "swr.cn-north-**.myhuaweicloud.com/**/nginx:latest": rpc error: code = Unknown desc = failed to pull and unpack image "swr.cn-north-7.myhuaweicloud.com/**/nginx:latest": failed to resolve reference "swr.cn-north-7.myhuaweicloud.com/**/nginx/latest": failed to do request: Head "https://swr.cn-north-**.myhuaweicloud.com/v2/**/nginx/manifests/latest": dial tcp 100.79.**.**:443: i/o timeout
Fault Location
The error information indicates that the SWR image cannot be pulled during workload creation. Check whether the VPC endpoints for accessing OBS and SWR are running properly.
Parent Topic: Workload Exceptions
