Updated on 2026-11-16 GMT+08:00
Terraform Overview
Terraform is an infrastructure as code (IaC) tool developed by HashiCorp. It provides both the Community and Enterprise editions. Terraform uses HashiCorp Configuration Language (HCL) to declaratively describe the desired state of infrastructure and provides unified resource lifecycle management for multi-cloud, network, on-premises, and SaaS environments.
Basic Concepts
The core workflow of Terraform consists of three steps.
Step
Write
You can write human-readable configuration files to define the desired resource configurations for the infrastructure. Terraform uses declarative configuration files, so developers only need to describe the final state of required resources.
Plan
Terraform compares the target state described in the configuration files with the current state of the infrastructure and generates an execution plan that describes how to transition from the current state to the desired state. The execution plan is presented as an infrastructure manifest.
Apply
After the execution plan is confirmed, Terraform executes the recommended actions in the correct sequence, with resource dependencies considered, and creates resources in the dependency sequence.
The following table describes the main components of Terraform.
Component
Configuration files
The core carrier for developers to define infrastructure resources. It is used to declare the required provider, resources, and their configuration parameters.
Modules
A reusable infrastructure code unit that encapsulates complex architectures into modular templates to avoid repeated coding
State files
Files that record the current state of the infrastructure, including the relationships between components, configurations, and resources
Providers
Plugins for Terraform to interact with the APIs of external services and platforms, allowing Terraform to manage resources in the environment
Terraform CLI
Terraform's command-line tool, which is used to initialize the working directories, generate execution plans, apply changes, and interact with core components
Advantages of Terraform
  • Multi-cloud management
    Terraform is suitable for multi-cloud solutions. O&M personnel can use Terraform to centrally manage resources on multiple clouds, including Huawei Cloud.
  • Automatic infrastructure management
    Terraform can create templates for configuration files, enabling automatic and rapid resource creation without the need for interaction.
  • High reusability and modularization
    Common architecture configurations can be compiled into reusable modules for quick and standardized replication.
  • Lower development costs
    You can create development and deployment environments on demand to reduce costs.
Using Terraform to Manage CCE Resources
Terraform can use the following types of resources to manage CCE clusters and related resources:
  • Resources: newly created resources
  • Data source: used to query existing resources and obtain their attributes
Resource List
Name
Purpose
huaweicloud_cce_access_policy
Grants RBAC permissions to a CCE cluster.
huaweicloud_cce_addon
Deploys add-ons in a CCE cluster.
huaweicloud_cce_chart
Manages the charts of a CCE cluster.
huaweicloud_cce_cluster
Creates a CCE cluster.
huaweicloud_cce_cluster_certificate_revoke
Deletes the granted RBAC permissions.
huaweicloud_cce_cluster_log_config
Manages the log configuration of a CCE cluster.
huaweicloud_cce_cluster_pod_identity_association
Creates a pod identity association.
huaweicloud_cce_cluster_upgrade
Upgrades a CCE cluster.
huaweicloud_cce_image_cache
Creates a container image cache.
huaweicloud_cce_namespace
Creates a namespace in a CCE cluster.
huaweicloud_cce_node
Creates a node in a CCE cluster.
huaweicloud_cce_node_attach
Adds an ECS to a CCE cluster for management.
huaweicloud_cce_node_pool
Creates a node pool in a CCE cluster.
huaweicloud_cce_node_pool_nodes_add
Adds a node in a CCE cluster to a specified node pool.
huaweicloud_cce_node_pool_scale
Scales a node pool in a CCE cluster.
huaweicloud_cce_node_sync
Synchronizes cloud server information to a CCE node.
huaweicloud_cce_nodes_certificate_rotatecredentials
Rotates a user's cluster certificate.
huaweicloud_cce_nodes_remove
Deletes a CCE node.
huaweicloud_cce_partition
Creates a CCE node partition.
huaweicloud_cce_pvc
Creates a PVC in a CCE cluster.
huaweicloud_cce_release
Deploys an application template in a CCE cluster.
Data Source List
Name
Purpose
huaweicloud_cce_access_policies
Obtains the existing RBAC permissions of a CCE cluster.
huaweicloud_cce_addon_template
Obtains the add-on configuration template of a CCE cluster.
huaweicloud_cce_addons
Obtains the add-on deployment information in a CCE cluster.
huaweicloud_cce_chart_values
Obtains the values of a chart.
huaweicloud_cce_charts
Obtains the chart list of a CCE cluster.
Obtains information about a CCE cluster.
Obtains the authentication credential of a CCE cluster.
huaweicloud_cce_cluster_configuration_details
Obtains the configuration details of a CCE cluster.
huaweicloud_cce_cluster_configurations
Obtains the existing configuration of a CCE cluster.
huaweicloud_cce_cluster_pod_identity_assume_agency
Obtains pod identity association information of a CCE cluster.
huaweicloud_cce_cluster_upgrade_info
Obtains the upgrade information of a CCE cluster.
huaweicloud_cce_clusters
Obtains the list of existing CCE clusters.
huaweicloud_cce_flavor_specifications
Obtains available CCE cluster specifications.
huaweicloud_cce_image_caches
Obtains the image cache list.
Obtains the node information of a CCE cluster.
Obtains the node pool information of a CCE cluster.
huaweicloud_cce_node_pools
Obtains the node pool list of a CCE cluster.
Obtains the node list of a CCE cluster.
huaweicloud_cce_releases
Obtains the charts that have been deployed in a CCE cluster.
