Creating IAM Users and Granting the Minimum CCE Permissions
Your Huawei Cloud account has all permissions. Using this account to perform routine operations is risky. Misoperations may cause resource unavailability or data leakage. In team collaboration scenarios, different members require different permissions. Using an account cannot isolate permissions.
You are advised to create IAM users and grant them only the minimum permissions required for operations to reduce security risks. This section describes how to use Terraform to create an IAM user group and IAM users and grant CCE system permissions to the user group for fine-grained permission control.
- Your account has IAM administrator permissions (for example, IAMFullPolicy) to create users, user groups, and grant permissions.
- Terraform has been installed. For details, see Installing Terraform and Configuring the Huawei Cloud Provider.
Step 1: Create a Project Directory and Initialize the Configuration
- Create an IAM user management directory (the directory name is user-defined).
mkdir terraform_iam_user cd ./terraform_iam_user
- Copy the prepared provider configuration file to the current directory. The init.tf file has been created in the terraform_hw_demo directory in section "Installing Terraform and Configuring the Huawei Cloud Provider".
cp ../terraform_hw_demo/init.tf .
Step 2: Create Configuration Files
All the following configuration files are created in the project directory.
- Query IAM policies.
Create the policy_data.tf file to query system-defined policies and filter them by name.
variable "policy_type" { description = "The type of the policy" type = string default = "system" } variable "policy_names" { description = "The name list of policies to be associated with the user group" type = list(string) } # Obtain all IAM policies in a specified region (if the region parameter is not specified, the region specified in the provider block is used by default). data "huaweicloud_identityv5_policies" "test" { policy_type = var.policy_type } # Filter the policies by policy name. locals { filtered_policies = [for policy in data.huaweicloud_identityv5_policies.test.policies : policy if contains(var.policy_names, policy.policy_name)] }The involved parameters are described in the table below.
policy_type
Policy type. Options:
- system (default): indicates a system-defined policy.
- custom: indicates a custom policy.
policy_names
List of policy names to be attached to the user group.
- Create a user group.
Create the group.tf file and create an IAM user group.
variable "group_name" { description = "The name of the user group" type = string } variable "group_description" { description = "The description of the user group" type = string default = "" } # Create an IAM user group in the specified region (if the region parameter is not specified, the region specified in the provider block is used by default). resource "huaweicloud_identityv5_group" "test" { group_name = var.group_name description = var.group_description }The involved parameters are described in the table below.
group_name
User group name.
group_description
User group description.
- Create the group_attach.tf file to grant permissions to the user group.
# Create IAM policies and attach them with the user group in the specified region (if the region parameter is not specified, the region specified in the provider block is used by default). resource "huaweicloud_identityv5_policy_group_attach" "test" { count = length(local.filtered_policies) policy_id = try(local.filtered_policies[count.index].policy_id, null) group_id = huaweicloud_identityv5_group.test.id depends_on = [ huaweicloud_identityv5_group.test ] }The involved parameters are described in the table below.
count
Number of resources to be created, which is equal to the number of policies to be attached.
policy_id
Policy ID, which can be obtained from the query result in step 1.
group_id
User group ID, which is the ID of the user group created in step 2.
- Create the users.tf file to create IAM users.
variable "users_configuration" { description = "IAM user configuration" type = list(object({ name = string password = optional(string, "") })) nullable = false } # Create IAM users in the specified region (if the region parameter is not specified, the region specified in the provider block is used by default). resource "huaweicloud_identity_user" "test" { count = length(var.users_configuration) name = lookup(var.users_configuration[count.index], "name", null) password = lookup(var.users_configuration[count.index], "password", null) }The involved parameters are described in the table below.
name
Username.
password
User password. Reset the password upon the first login to the console.
- Add the users to the user group.
Create the group_members.tf file and add the users created in step 4 to the user group created in step 2. The users will inherit all permissions of the user group.
resource "huaweicloud_identity_group_membership" "test" { count = length(var.users_configuration) group = huaweicloud_identityv5_group.test.id users = huaweicloud_identity_user.test[*].id depends_on = [ huaweicloud_identityv5_group.test, huaweicloud_identity_user.test ] }The involved parameters are described in the table below.
group
users
User ID list, which contains the IDs of all users created in step 4.
- Configure resource parameters.
Create the terraform.tfvars file and preset the input parameters required by the resources. The following is an example configuration. Modify the parameters based on service requirements.
# IAM user group configuration group_name = "cce_operate" group_description = "CCE resource management" # IAM policy configuration policy_type = "system" policy_names = [ "CCEFullPolicy" # Policy name. This policy has all permissions on CCE. ] # IAM user configuration users_configuration = [ { name = "cce_use" # Username password = "*******" # User password. The password needs to be reset upon the first login to the console. } ]The involved parameters are described in the table below.
group_name
User group name, for example, cce_operate.
group_description
policy_type
Policy type. For example, system indicates a system-defined policy.
policy_names
Policy name list. For example, CCEFullPolicy indicates full access to CCE. If the minimum permissions are required, replace it with CCEReadOnlyPolicy (CCE read-only permissions).
users_configuration
User configuration list, including the username and password.
Step 3: Initialize and Apply the Terraform Configuration
- Initialize the environment.
terraform init
- View the execution plan and check whether the resource changes meet your expectation.
terraform plan
- After confirming the plan, create resources. Terraform will ask for your confirmation. Enter yes to confirm the execution.
terraform apply
- View the created resources.
terraform show
Step 4: Clear Resources
If you no longer need the resources created by Terraform, run the following command to release them: Terraform will ask for your confirmation. Enter yes to confirm the execution.
This operation will permanently delete the user group, all IAM users, and authorization relationships created by Terraform. Ensure that you no longer need them before performing this operation.
terraform destroy
Helpful Links
- Installing Terraform and Configuring the Huawei Cloud Provider: how to install Terraform and configure the Huawei Cloud provider
- System-defined policies supported by CCE: Permissions Management
- Creating a CCE Cluster Using Terraform: how to create a CCE cluster using Terraform
