Containerizing and Using QingTian Enclave on CCE
QingTian Enclave is a next-generation security structure introduced to QingTian-backed ECSs. QingTian Enclave instances are completely isolated VMs without persistent storage, interactive access, or external networking. They ensure the temporary, secure storage of data, provide a highly secure, isolated execution environment, and can run sensitive tasks and applications. For details, see What Is QingTian Enclave?
QingTian Enclave has the following features:
- Completely independent VMs: A QingTian Enclave instance is an independent VM built within an ECS. It has its own OS and resources and is logically isolated from the host ECS to ensure high security.
- No persistent storage: QingTian Enclave instances have no persistent storage. All data is lost after the instances are shut down. This ensures the temporary, secure storage of data, preventing data leakage.
- No interactive access or external networking: QingTian Enclave instances do not support interactive access, such as SSH connections. They cannot access external networks. They can only communicate with the host ECSs through internal secure channels.
- High isolation and access control: The root user on the host ECSs cannot directly access the QingTian Enclave instances. Any user or process on a host ECS must communicate with the QingTian Enclave instances through a secure local channel (vsock). This channel ensures the security and integrity of data transmission and prevents man-in-the-middle attacks and data leakage.
QingTian Enclave instances are applied to:
- Sensitive data processing: They can process sensitive data, such as encryption keys and personal identity information. They ensure that the data is not disclosed during the processing.
- Secure computing: They provide an isolated environment for highly secure computing tasks to prevent interference from malicious software or attackers.
- Privacy protection: They can protect your private data and ensure the security of sensitive information during transmission and processing.
Typically, a QingTian Enclave instance can be directly created on a QingTian-backed ECS. However, this setup does not support dynamic instance scaling and cannot automatically adjust based on fluctuations in service volume. This section describes how to containerize and use a QingTian Enclave instance in a CCE cluster and use Kubernetes scheduling and scaling capabilities for service scalability.
Solution Architecture
To deploy QingTian Enclave in a CCE cluster, install the add-on for containerizing QingTian Enclave and package a QingTian Enclave image file (.eif) into a container image. After completing these steps, you can create QingTian Enclave containers within the CCE cluster. kubelet allocates and schedules such containers through the /dev/qtbox_service0 API for managing QingTian Enclave instance lifecycle.
Compared with running QingTian Enclave instances on VMs, running QingTian Enclave containers splits services into untrusted and trusted components. The untrusted components include external service components of an application and components related to QingTian enclave instance management (such as the qt-enclave tool). The trusted components include services that involve encryption and decryption or sensitive information protection and run in a QingTian Enclave instance.
When running QingTian Enclave containers, qt-enclave is used to create a QingTian Enclave instance through a secure local channel (vsock) to run services that require encryption, decryption, or sensitive information protection.
A CCE standard or Turbo cluster is available.
Managing a QingTian Enclave Instance in a CCE Cluster
- Log in to the ECS console, create an ECS that supports the QingTian Enclave feature, for example, a C7t ECS with 4 vCPUs and 8 GiB of memory or a higher flavor, and use Linux as the system image. (Huawei Cloud EulerOS 2.0 is recommended). In the Trusted Settings area, select Enclave.
- Configure the ECS to be managed by CCE and pay attention to the following settings:
- Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Nodes. In the right pane, click the Nodes tab and click Accept Node in the upper right corner.
- Click Select Cloud Server and select the created ECS.
- Install the components that support the QingTian Enclave feature on the node by running the script and enter the following parameters in the Post-installation Command area in Advanced Settings:
curl -k https://cce-statics.ap-southeast-3.obs.ap-southeast-3.myhuaweicloud.com/job-platform-package/cce-addons/addons-qt-enclave-20250417103811268.zip -o /tmp/addons-qt-enclave.zip cd /tmp unzip addons-qt-enclave.zip cd addons bash post_install.sh
- Configure other parameters as required to complete node management. For details about the parameters, see Accepting Nodes for Management.
After the node has been managed, locate the row containing this node and choose More > View YAML in the Operation column. You can see that there are schedulable QingTian Enclave resources in the YAML file.
Building and Using a QingTian Enclave Container Image
- Prepare an ECS that runs Huawei Cloud EulerOS 2.0 and supports the QingTian Enclave feature and build a QingTian Enclave image file named hello-enclave.eif. For details, see Getting Started with QingTian Enclave.
- Log in to the ECS and install Docker for image builds.
- Confirm that the repository is configured properly.
Check whether the parameters in the /etc/yum.repos.d/hce.repo file are configured properly. The proper configuration is as follows:
[base] name=HCE $releasever base baseurl=https://repo.huaweicloud.com/hce/$releasever/os/$basearch/ enabled=1 gpgcheck=1 gpgkey=https://repo.huaweicloud.com/hce/$releasever/os/RPM-GPG-KEY-HCE-2 [updates] name=HCE $releasever updates baseurl=https://repo.huaweicloud.com/hce/$releasever/updates/$basearch/ ......
- Install the Docker software package.
yum install docker -y
- Install qt CLI, configure parameters for resource isolation in the configuration file as required, and enable resource isolation. To use qt CLI, install the necessary Python libraries. For details, see QingTian CLI (qt CLI).
yum install qt-enclave-bootstrap yum install virtio-qtbox yum install qingtian-tool
Install the required Python libraries.
pip3 install docker knack
- Configure parameters for resource isolation in the configuration file and enable resource isolation. In this practice, 1 GiB of memory and 2 vCPUs are used.
systemctl start qt-enclave-env
Build a QingTian Enclave image. In this practice, the hello_enclave.sh script is used as the QingTian Enclave application.
vi hello_enclave.sh
The content is as follows:
#!/bin/bash while true do echo "hello enclave!" sleep 2 doneCreate a Dockerfile.
vi Dockerfile
FROM ubuntu:latest COPY hello_enclave.sh /root/hello_enclave.sh CMD ["/root/hello_enclave.sh"]
- Check that the script has execution permissions.
chmod +x hello_enclave.sh
- Build a Docker image named hello-enclave.
docker build -f Dockerfile -t hello-enclave .
- Run the qt enclave make-img command to convert the Docker image to a QingTian Enclave image file named hello-enclave.eif.
qt enclave make-img --docker-uri hello-enclave --eif hello-enclave.eif
The output is as follows:
{ "digest": "SHA384", "PCR0": "63bf78ece7d2388ff773d0cad2ebc9a3070359db46d567ba271ff8adfb8b0b091be4ff4d5dda3f1c83109096e3656f3b", "PCR8": "000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000" }
- Use hello-enclave.eif to build a container image. The built container image has the QingTian Enclave feature.
- Set up a container build environment.
mkdir container cd container cp /usr/local/bin/qt . cp /etc/qingtian/enclave/qt-enclave-env.conf . cp /root/hello-enclave.eif .
- Create a Dockerfile in the container directory.
vi Dockerfile
The content is as follows:FROM ubuntu RUN apt update && \ apt install -y python3 && \ apt install -y python3-pip && \ apt install -y python3-docker && \ apt install -y python3-knack && \ apt install -y libcjson-dev && \ apt install -y libglib2.0-dev && \ ln -s /usr/bin/python3 /usr/bin/python && \ mkdir -p /etc/qingtian/enclave && \ mkdir -p /var/log/qingtian_enclaves && \ mkdir -p /var/log/qlog COPY qt-enclave-env.conf /etc/qingtian/enclave/ COPY qt /usr/bin COPY hello-enclave.eif / COPY entrypoint.sh / ENTRYPOINT /entrypoint.sh - Create entrypoint.sh in the container directory.
vi entrypoint.sh
The content is as follows:#!/bin/bash qt enclave start --mem 4096 --cpus 2 --eif hello-enclave.eif --cid 4--debug-mode qt enclave console --enclave-id 0
- Build a container image with the QingTian Enclave feature.
docker build -f Dockerfile -t enclave-demo .
- Push the container image to SWR and use it in a Kubernetes cluster. For details, see Pushing an Image.
Deploying a QingTian Enclave Container in a CCE Cluster
- Create an enclave-deployment.yaml file and deploy a workload.An example is shown below. You need to replace the image address with the one pushed to SWR during the image build.
kind: Deployment apiVersion: apps/v1 metadata: name: hello-enclave namespace: default spec: replicas: 1 selector: matchLabels: app: hello-enclave version: v1 template: metadata: labels: app: hello-enclave version: v1 spec: containers: - name: container-1 image: swr.ap-southeast-3.myhuaweicloud.com/container/enclave-demo:latest resources: limits: cpu: 250m huawei.com/qt_enclaves: '1' hugepages-1Gi: 4Gi memory: 512Mi requests: cpu: 250m huawei.com/qt_enclaves: '1' hugepages-1Gi: 4Gi memory: 512Mi imagePullPolicy: IfNotPresent securityContext: seccompProfile: type: Unconfined - Create the workload.
kubectl create -f enclave-deployment.yaml
Information similar to the following is displayed:
deployment.apps/hello-enclave created
- Check the pod status.
kubectl get pod | grep hello-enclave
hello-enclave-587b9f6d49-bvq22 1/1 Running 0 38s
- View the pod logs.
kubectl logs hello-enclave-587b9f6d49-bvq22 --tail=10
If information similar to the following is displayed, the QingTian Enclave container is functioning properly:
hello enclave! hello enclave! hello enclave! hello enclave! ...
